It is currently Sat May 10, 2025 8:53 pm
Reply to topic  [ 10 posts ]
 worn down prop
Post worn down prop
How bad could a worn down prop effect speed? I have a 2007 MB 23 mini. And after running the river of course finding a few sand bars hard i noticed on the lake that im only running around 10 mph vs the 21 mph with about the same loads. 2 guys 2 dozen dekes and other small gear in a 1648 alumacraft jon. Or do i have something else going on.
Thanks
Torrey
Thu Oct 13, 2011 8:49 pm
Post Re: worn down prop
My guess is you found out for yourself. Aside from the engine actually running it has everything to do with speed. :lol: Sand+props=Devil. :lol:
18x48 Charles Leonard / 36PD
Thu Oct 13, 2011 8:52 pm
Rpms seem to be aboat the same but from what i read they are a little higher then most at 4100 in water and the over all length is 9.5 inches and one blade is like 5 inches or little under wide. Just wanted to make sure before i tried to order one. Any suggestions on what i should get and best place to order from not sure if there is a dealer near me
Thankd
Thu Oct 13, 2011 9:01 pm
MB only offers 1 prop for the mini, an 11x10. However you need to remove it and see if you have a hex or threaded shaft.
And where are you?
Thu Oct 13, 2011 9:04 pm
Mankato, mn
Thu Oct 13, 2011 9:05 pm
You'd have to call MB to find out who is the closest.
The only dealer I know of in that region is in Lacrosse. If you want his info pm me.
Thu Oct 13, 2011 9:11 pm
Thanks i will try to call mudd buddy agaun tomorrow tried today
Thu Oct 13, 2011 9:38 pm
Order it straight from Mud Buddy. It will be easier than trying to find someone around So. Mn.
Sent you a PM
Mag10
Fri Oct 14, 2011 12:06 pm
I think Backwater is in MN, they make props and motors, might be able to help you out
Mon Oct 17, 2011 12:03 pm
Users browsing this forum: No registered users and 116 guests
