Scoot72
 Mudd Buddy Electric Tilt
I have a 2005 HD35 Mudd Buddy motor and the tilt has been giving me problems. I tore it apart and everything looks normal. Needed some grease. I cleaned it up and regreased it. Hooked it up to the motor just to check it. Hit the switch and the shaft rotated. I bolted it back up and nothing but a bunch of clicking. Took it back off and checked it to see if it still was working. I took two welding rods and put them in the bolt hole and hit the switch. It twisted them up. Put 3 rods in and wouldn't bend them. I know its a screw drive but can't figure out how to get the drive itself out. Does anyone have any ideas?
| Sat Apr 28, 2012 8:56 pm |
deltaduckmaster
Put insurance on it and blow it up!! Bawha
_________________ 17x48 extreme stage 2 GTR 20X60 DUAL RIG BOWFISHING ADDITION http://www.scalesandtailsbowfishing.com
| Sat Apr 28, 2012 9:02 pm |
Scoot72
 Re: Mudd Buddy Electric Tilt
Sorry don't find the humor on that reply. I asked for help not for a smarta** comment.
| Sat Apr 28, 2012 9:15 pm |
cb5331
Welcome to MMT.  I'm sure you'll get some help eventually, just have to wait on one of the mudbuddy guys to log in. You may also try the search feature, if you haven't already. They've had several different trims on their motors and I'm pretty sure I've seen tear down instructions on more than one of them.
| Sat Apr 28, 2012 9:18 pm |
med
Joined: Wed Jan 14, 2009 8:25 am Posts: 6432 Location: the dark side of the moon
You check over on the mb Site?
_________________ 1850 & 36pd
| Sat Apr 28, 2012 9:29 pm |
deltaduckmaster
Bawhaha
sela_native
ddm you sure are on a roll hahaha
_________________ 1650 ribbed abused by a Gt-35 and push pole reverse
| Sat Apr 28, 2012 9:35 pm |
deltaduckmaster
On number 14 right now weight till I get to 30 or so !! Lol
| Sat Apr 28, 2012 9:37 pm |
deltaduckmaster
I will take over the post count tonight at everybody's expense!! Jason hour toast dic!!
| Sat Apr 28, 2012 9:39 pm |
dwight37
I just had mine all apart and put it back together ill try to help ya out if I can. First of all is the bolt that holds the bottom of the trim unit loose so it can slide up and down in the track? Is it a bear or Thomson trim unit? Pm me if this isn't the problem!
| Mon Apr 30, 2012 12:45 pm |
Scoot72
Yes that was my first thought that it had bound up but not the case. It is a bear. Finally got it apart and there was a washer in pieces that fell out. Trying to find one now.
| Mon Apr 30, 2012 1:07 pm |
fowl habbit
Joined: Sat Jan 16, 2010 1:52 pm Posts: 1130 Location: THE ONE AND ONLY BUFFALO COUNTY
If its the old bear unit I would just replace the whole thing with the Thomson trim untit, Its still not nearly as good as the mercury trim unit but will last longet than the bear will, If I remeber right you can get the whole thing for a littel over $100 bucks
| Mon Apr 30, 2012 1:19 pm |
Smoke
Joined: Fri Jan 23, 2009 1:27 pm Posts: 1095 Location: SW Michigan
If you would check ur same thread on mb forum I answered all your questions and told ya i'd help ya out. You'll get no simpathy over here on a mud buddy motor. So slow ur roll their just bustin on ya a bit. Nothing personal and if it is fork em!
Smoke
_________________ 1854 Prodigy Open HDR/Stage 3 mods Prodigy Boats Pro Staff BPS Swamp Staff Member Blackwater Marine LLC.
| Mon Apr 30, 2012 5:43 pm |
Quackkillz
Joined: Sun Dec 04, 2011 4:57 am Posts: 535 Location: Bottom of da boot
I just changed mine Saturday, it is a Thompson trim, I ordered it for $260 and it comes with all the hardware if your upgrading from a bear to a Thompson.
_________________ 1648 weld bilt being followed by a 35 gtr
| Mon Apr 30, 2012 11:28 pm |
