It is currently Wed Dec 17, 2025 2:12 am
Reply to topic  [ 14 posts ]
 Mudd Buddy Electric Tilt
Post Mudd Buddy Electric Tilt
I have a 2005 HD35 Mudd Buddy motor and the tilt has been giving me problems. I tore it apart and everything looks normal. Needed some grease. I cleaned it up and regreased it. Hooked it up to the motor just to check it. Hit the switch and the shaft rotated. I bolted it back up and nothing but a bunch of clicking. Took it back off and checked it to see if it still was working. I took two welding rods and put them in the bolt hole and hit the switch. It twisted them up. Put 3 rods in and wouldn't bend them. I know its a screw drive but can't figure out how to get the drive itself out. Does anyone have any ideas?
Sat Apr 28, 2012 8:56 pm
Put insurance on it and blow it up!! Bawha
17x48 extreme stage 2 GTR
Sat Apr 28, 2012 9:02 pm
Post Re: Mudd Buddy Electric Tilt
Sorry don't find the humor on that reply. I asked for help not for a smarta** comment.
Sat Apr 28, 2012 9:15 pm
Welcome to MMT. :lol: I'm sure you'll get some help eventually, just have to wait on one of the mudbuddy guys to log in. You may also try the search feature, if you haven't already. They've had several different trims on their motors and I'm pretty sure I've seen tear down instructions on more than one of them.
Sat Apr 28, 2012 9:18 pm
You check over on the mb Site?
1850 & 36pd
Sat Apr 28, 2012 9:29 pm
Bawhaha
ddm you sure are on a roll hahaha
1650 ribbed abused by a Gt-35 and push pole reverse
Sat Apr 28, 2012 9:35 pm
On number 14 right now weight till I get to 30 or so !! Lol
Sat Apr 28, 2012 9:37 pm
I will take over the post count tonight at everybody's expense!! Jason hour toast dic!!
Sat Apr 28, 2012 9:39 pm
I just had mine all apart and put it back together ill try to help ya out if I can.
First of all is the bolt that holds the bottom of the trim unit loose so it can slide up and down in the track?
Is it a bear or Thomson trim unit?
Pm me if this isn't the problem!
Mon Apr 30, 2012 12:45 pm
Yes that was my first thought that it had bound up but not the case. It is a bear. Finally got it apart and there was a washer in pieces that fell out. Trying to find one now.
Mon Apr 30, 2012 1:07 pm
If its the old bear unit I would just replace the whole thing with the Thomson trim untit, Its still not nearly as good as the mercury trim unit but will last longet than the bear will, If I remeber right you can get the whole thing for a littel over $100 bucks
Mon Apr 30, 2012 1:19 pm
If you would check ur same thread on mb forum I answered all your questions and told ya i'd help ya out. You'll get no simpathy over here on a mud buddy motor. So slow ur roll their just bustin on ya a bit. Nothing personal and if it is fork em!
Smoke
1854 Prodigy Open
HDR/Stage 3 mods
Prodigy Boats Pro Staff
BPS Swamp Staff Member
Blackwater Marine LLC.
Mon Apr 30, 2012 5:43 pm
I just changed mine Saturday, it is a Thompson trim, I ordered it for $260 and it comes with all the hardware if your upgrading from a bear to a Thompson.
Mon Apr 30, 2012 11:28 pm
