It is currently Mon May 12, 2025 10:51 am
Reply to topic  [ 17 posts ]
 Stainless Steel props?
Post Stainless Steel props?
Im wodering if a stainless steel prop will make a difference on a 15? Thanks for any info.
27 GDLT pushing a War Eagle 1542
Wed Apr 25, 2012 8:23 pm
Post Re: Stainless Steel props?
Do what?
Wed Apr 25, 2012 9:37 pm
How much of a difference with a stainless prop compared to a aluminum prop?
Thu Apr 26, 2012 7:51 am
Thu Apr 26, 2012 8:23 am
Msm, alright i appriciate it.
Thu Apr 26, 2012 8:41 am
A 15 outboard? All mm's have (or should have) steel props.
HOTSAUCE170 wrote:
Fri Apr 27, 2012 9:43 am
Fri Apr 27, 2012 10:34 am
Don't do it. Waste of money and can cause major damage. The thing is stainless props are only good on higer hp motors because aluminum props tend to flex with the higher hp. A smaller hp like your 15 wont make any difference. Also if you hit something with the stainless hard your looking at bending or breaking your prop shaft and seals. With an aluminum it will just chip off.
1542 War Eagle with 25hp GDLT
Fri Apr 27, 2012 10:53 am
Fri Apr 27, 2012 1:59 pm
Man for real? too much prop and will break a shaft? In fact get right diameter and pitch it will perform better since an aluminum does lose pitch due to flex when in use. as for breaking a shaft, not gonna happen, there is a rubber bushing that will slip before breaking shaft.
Fri Apr 27, 2012 4:56 pm
Profile YIM
Fri Apr 27, 2012 10:05 pm
I have a 40 merc and the aluminum prop is a spare to the stainless
Fri Apr 27, 2012 10:11 pm
Yeah, okay :roll:
Tell that to the hundreds of people around here who put their outboards through hell in the stump fields with stainless props. I've seen the prop spin out, get bent, and even the lower unit get torn off. But never shaft or seal damage because of a stainless prop.
Fri Apr 27, 2012 11:36 pm
ive rebuilt 5 lower units thats a small percent but they have all had broken lower unit gears or broken shafts do to hitting stumps and rocks using stanless steel props i also read that some of the manufactures are starting to void warrantys on small motors if a stanless is put on and their is a failure in the lower unit
Sat Apr 28, 2012 7:38 am
Plus, you can rebuild an aluminum prop easily. SS, not so much.
1750 Gator Trax HD, MB 5000.
Sat Apr 28, 2012 7:42 am
The first thing we do wif a new o/b is put a stainless wheel on it. Aluminum is good for lake boats. Sand eats an aluminum prop in seconds. Lillies will even twist the blades all up.
18'x54"CC Hanko/ 36PD
Wed May 23, 2012 1:37 am
so your saying a 3 cyl 40 merc can flex a stainless prop? thats your ass. them little motors got tons of ass!
Wed May 23, 2012 5:47 am
Users browsing this forum: No registered users and 73 guests
