david95
Joined: Thu Jan 12, 2012 5:15 pm Posts: 641 Location: Summerville, South Carolina
 Stainless Steel props?
Im wodering if a stainless steel prop will make a difference on a 15? Thanks for any info.
_________________ 27 GDLT pushing a War Eagle 1542
Wed Apr 25, 2012 8:23 pm |
Woodiebuster
 Re: Stainless Steel props?
Do what?
Wed Apr 25, 2012 9:37 pm |
david95
How much of a difference with a stainless prop compared to a aluminum prop?
Thu Apr 26, 2012 7:51 am |
msm8281
Joined: Fri Oct 09, 2009 1:50 pm Posts: 9673 Location: New Iberia, La.
Thu Apr 26, 2012 8:23 am |
david95
Msm, alright i appriciate it.
Thu Apr 26, 2012 8:41 am |
mizzippi jb
Joined: Wed Sep 21, 2011 2:53 pm Posts: 5077 Location: The duck Mecca called Ga!
A 15 outboard? All mm's have (or should have) steel props.
_________________ HOTSAUCE170 wrote: I've never gone to Seminole for the amenities/luxury the two reasons I go down there are to kill shit and get fucked up with like minded individuals aka OG'S. If you want to swirl wine and stay in a room where politics and investment diversity are discussed (with no roaches) lake lanier is near Atlanta. If you wanna have an awesome time and maybe stay in a room where children were conceived on one side and someone got stabbed over an 8-ball on the other come on down I got a can of raid.
Fri Apr 27, 2012 9:43 am |
david95
Fri Apr 27, 2012 10:34 am |
WAD SHOOTER
Joined: Sun May 16, 2010 4:30 pm Posts: 667 Location: Clinton, MS
Don't do it. Waste of money and can cause major damage. The thing is stainless props are only good on higer hp motors because aluminum props tend to flex with the higher hp. A smaller hp like your 15 wont make any difference. Also if you hit something with the stainless hard your looking at bending or breaking your prop shaft and seals. With an aluminum it will just chip off.
_________________ 1542 War Eagle with 25hp GDLT
Fri Apr 27, 2012 10:53 am |
david95
Fri Apr 27, 2012 1:59 pm |
bobbyjober
Joined: Sun Aug 08, 2010 3:28 pm Posts: 546 Location: St. Martinville, La
Man for real? too much prop and will break a shaft? In fact get right diameter and pitch it will perform better since an aluminum does lose pitch due to flex when in use. as for breaking a shaft, not gonna happen, there is a rubber bushing that will slip before breaking shaft.
_________________ 1542 FLATBOTTOM WITH 24 HONDA MUD BUDDY MINI TURNING A 12" GDSD PROP/17 FT XPRESS CENTER CONSOLE WITH 90 MARINER
Fri Apr 27, 2012 4:56 pm |
WAD SHOOTER
Fri Apr 27, 2012 10:05 pm |
duckduckboom
Joined: Tue Nov 23, 2010 6:33 pm Posts: 5603 Location: Corner of Hell an high water, La
I have a 40 merc and the aluminum prop is a spare to the stainless
_________________ You have your whole life to be an idiot, take a day off!
Fri Apr 27, 2012 10:11 pm |
Woodiebuster
Yeah, okay Tell that to the hundreds of people around here who put their outboards through hell in the stump fields with stainless props. I've seen the prop spin out, get bent, and even the lower unit get torn off. But never shaft or seal damage because of a stainless prop.
Fri Apr 27, 2012 11:36 pm |
wm
Joined: Sat Feb 19, 2011 11:48 pm Posts: 782 Location: Eau Claire Wi
ive rebuilt 5 lower units thats a small percent but they have all had broken lower unit gears or broken shafts do to hitting stumps and rocks using stanless steel props i also read that some of the manufactures are starting to void warrantys on small motors if a stanless is put on and their is a failure in the lower unit
_________________ 1648 alumacraft with a 35 backwaterinc
Sat Apr 28, 2012 7:38 am |
centxhunter
Joined: Fri Jan 13, 2012 1:28 pm Posts: 357 Location: Austin, TX
Plus, you can rebuild an aluminum prop easily. SS, not so much.
_________________ 1750 Gator Trax HD, MB 5000.
Sat Apr 28, 2012 7:42 am |
pooldoo73
Joined: Tue Jan 25, 2011 5:47 pm Posts: 886 Location: Plaquemine
The first thing we do wif a new o/b is put a stainless wheel on it. Aluminum is good for lake boats. Sand eats an aluminum prop in seconds. Lillies will even twist the blades all up.
_________________ 18'x54"CC Hanko/ 36PD
Wed May 23, 2012 1:37 am |
CLICKSTER
so your saying a 3 cyl 40 merc can flex a stainless prop? thats your ass. them little motors got tons of ass!
Wed May 23, 2012 5:47 am |
