It is currently Mon Dec 22, 2025 11:30 am
Reply to topic  [ 31 posts ]
 Propeller Shaft Breaks off
Post Propeller Shaft Breaks off
I have a Mudbuddy 5500 with balanced drive / This past weekend i took the boat out for a ride and all of a sudden right where the end of the shaft is / where the thread starts on the shaft, breaks off along with the propeller. Now need a new propeller and propeller shaft.
My shaft size is a 32" 7/8 inch
Has this happened to any of you guys.
Tue Sep 04, 2012 8:12 pm
Post Re: Propeller Shaft Breaks off
I'll go ahead and save you two days and 150 posts worth of back and forth BS and skip to the end.
Buy a Gatortail, you'll have instant reverse and be bff with DDM... :roll:
Tue Sep 04, 2012 8:22 pm
I heard your dick actually will grow at least 4 to 6 inches as soon as you buy a gatortail.
Tue Sep 04, 2012 10:22 pm
Wed Sep 05, 2012 12:42 am
Wells sounds like to me that pretty much is a replica of a gd!! So with that being the issue I'm sure it's pretty common for lower units to fail so often!!
Robin we already know you carry more tools than any Gtr owner I know!! You might want to go order a new seal for that 100 hr grease job in that housing since theirs no other way to grease it!!
17x48 extreme stage 2 GTR
Wed Sep 05, 2012 5:38 am
Rare but it does happen. Normally not at the time of impact. Impacts over time cause them to go out. Do you run a lot of rocks?
Wed Sep 05, 2012 5:45 am
Wed Sep 05, 2012 7:38 am
You forgot the biggest tool of all!! YOU
Wed Sep 05, 2012 8:30 am
Wed Sep 05, 2012 8:31 am
Doug a Gtr has a seal go out it's a lower unit problem. But if a gd has a seal go out it's not a lower unit issue!! Do a search on seals bud!!
Wed Sep 05, 2012 8:38 am
Wed Sep 05, 2012 8:41 am
Yep he did. Also Hunter broke his PD shaft. If you hit shit over and over it will break I do not care what you drive. Robin have you ran swamp with stumps, logs, mud, and veggies? Hard on equipment.
Bayou Surface Drive
337-351-0362
Tarkington, TX 77327
Wed Sep 05, 2012 8:47 am
Wed Sep 05, 2012 8:50 am
OP: check the casing on the LU. A bud a mine known as Marktank on here has a second LU due ta the 1st one cracking around the welds on the skeg and runnin around the shaft casing. He just got a new one and within 2 weeks the same things started again.
Wildberry "Between You, Will, DUCK HEARSE, and PODCAST I have trouble reading anything on here"
23GTR stage 2 by Calen pushin a 1746 Kliebert
Wed Sep 05, 2012 9:08 am
Wed Sep 05, 2012 9:43 am
MMT - Where the Chit flys !
Eat - Sleep - Hunt ! ! !
Wed Sep 05, 2012 10:19 am
MMT Moderator
GTB 1860 w/ 2019 GTR40XD-HO
Wed Sep 05, 2012 10:21 am
MMT Moderator
Wed Sep 05, 2012 10:22 am
viewtopic.php?f=41&t=29590
DDM - is this an ISSUE or a PROBLEM ????
:lol:
Wed Sep 05, 2012 10:25 am
Wed Sep 05, 2012 10:29 am
Bayou Surface Drive
337-351-0362
Wed Sep 05, 2012 10:49 am
MMT Moderator
Wed Sep 05, 2012 11:57 am
BAN HAMMER
Bayou Surface Drive
337-351-0362
Wed Sep 05, 2012 12:04 pm
Wed Sep 05, 2012 12:44 pm
Fri Sep 07, 2012 4:01 pm
1854 Sportsman's Fab
2046 Uncle-J Skiff
35 GTR
Fri Sep 07, 2012 5:38 pm
Wed Sep 26, 2012 6:08 pm
Wed Sep 26, 2012 6:44 pm
Wed Sep 26, 2012 7:51 pm
Ok you get 10 points back - that was a funny story....
:lol:
Wed Sep 26, 2012 7:59 pm
We are still laughing.
Wed Sep 26, 2012 8:11 pm
