med
Joined: Wed Jan 14, 2009 8:25 am Posts: 6432 Location: the dark side of the moon
 Pd lower Teflon sleeve removal
Any tips?... Other than a sawzall .. (thanks poker1)
_________________ 1850 & 36pd
Fri Nov 30, 2012 3:57 pm |
med
 Re: Pd lower Teflon sleeve removal
Update**
If you need to do this get a 3-4ft piece of heavy pvc. Get in the boat and insert into the tower and put it against the top lip off the sleeve (make sure you aren't on the metal piece inside the tower) and then beat the crap out of it working around the sides. Took me about 45 seconds. If you've attempted this you will appreciate this info.
Fri Nov 30, 2012 4:49 pm |
banded-mallard
Just out of curosity, did it go bad? and how did you notice it went bad?
Tue Dec 04, 2012 9:54 am |
med
Was having trouble putting it in reverse. The tension knob wouldn't hold it. Thought it was bad but when I got it out it wasn't.
Tue Dec 04, 2012 11:44 am |
Hyper Josh
Joined: Fri Dec 04, 2009 7:49 am Posts: 208 Location: Texarkana,Ar
Have you figured out what the grinding noise was yet?
_________________ 17x54 35GTR
Tue Dec 04, 2012 12:31 pm |
med
Yeah it was the upper lu bearing
Tue Dec 04, 2012 4:13 pm |
Will
What year and how many hours?
_________________ Before the internet, the majority of the village idiots stayed in their villages.
Tue Dec 04, 2012 4:20 pm |
med
06....140hrs
Tue Dec 04, 2012 9:23 pm |
banded-mallard
Med
I noticed today that when I tried to spin mine around in reverse, it wouldn't quite go. When I went to ratchet it around, I had to hold the lower unit to aid it. The black knob with the spring just under the reverse pin, if I tighten it, would it hold enough resistance to allow it to ratchet correctly?
Sat Dec 08, 2012 5:59 pm |
OwenDickeson
That is the entire purpose of that knob.
Sat Dec 08, 2012 6:00 pm |
banded-mallard
Good deal. Never knew wtf it was far.
Sat Dec 08, 2012 6:42 pm |
cb5331
Sat Dec 08, 2012 6:44 pm |
banded-mallard
10-4
Sat Dec 08, 2012 6:53 pm |
