It is currently Tue Jul 08, 2025 2:19 am
Reply to topic  [ 13 posts ]
 Pd lower Teflon sleeve removal
Post Pd lower Teflon sleeve removal
Any tips?... Other than a sawzall .. (thanks poker1)
1850 & 36pd
Fri Nov 30, 2012 3:57 pm
Post Re: Pd lower Teflon sleeve removal
Update**
If you need to do this get a 3-4ft piece of heavy pvc. Get in the boat and insert into the tower and put it against the top lip off the sleeve (make sure you aren't on the metal piece inside the tower) and then beat the crap out of it working around the sides. Took me about 45 seconds. If you've attempted this you will appreciate this info.
1850 & 36pd
Fri Nov 30, 2012 4:49 pm
Just out of curosity, did it go bad? and how did you notice it went bad?
Tue Dec 04, 2012 9:54 am
Was having trouble putting it in reverse. The tension knob wouldn't hold it. Thought it was bad but when I got it out it wasn't.
1850 & 36pd
Tue Dec 04, 2012 11:44 am
Have you figured out what the grinding noise was yet?
17x54 35GTR
Tue Dec 04, 2012 12:31 pm
Yeah it was the upper lu bearing
1850 & 36pd
Tue Dec 04, 2012 4:13 pm
What year and how many hours?
Tue Dec 04, 2012 4:20 pm
06....140hrs
1850 & 36pd
Tue Dec 04, 2012 9:23 pm
Med
I noticed today that when I tried to spin mine around in reverse, it wouldn't quite go. When I went to ratchet it around, I had to hold the lower unit to aid it. The black knob with the spring just under the reverse pin, if I tighten it, would it hold enough resistance to allow it to ratchet correctly?
Sat Dec 08, 2012 5:59 pm
That is the entire purpose of that knob.
Sat Dec 08, 2012 6:00 pm
Good deal. Never knew wtf it was far.
Sat Dec 08, 2012 6:42 pm
Sat Dec 08, 2012 6:44 pm
10-4
Sat Dec 08, 2012 6:53 pm
Users browsing this forum: Google [Bot] and 21 guests
