It is currently Fri Mar 20, 2026 3:57 am
Reply to topic  [ 91 posts ]  Go to page 1, 2, 3  Next
 prodrive props
Post prodrive props
whats the best running prop out there for a 36pd? it has performance cam, heads, and exaust on a 18'x42" skiff
Sat Jun 30, 2012 6:56 pm
Post prodrive props
The pro drive prop
35 GTR - 1754 Extreme
Sat Jun 30, 2012 7:02 pm
Post Re: prodrive props
Yep.
Sat Jun 30, 2012 7:04 pm
Putting the purchase on one Monday but I sure don't want to
1850 & 36pd
Sat Jun 30, 2012 7:30 pm
stock 36 prop?
Sat Jun 30, 2012 8:02 pm
Yeah
1850 & 36pd
Sat Jun 30, 2012 8:07 pm
I run a Hopkins wheels and I have a brand new stock prop theres a big difference between the 2
Wed Jul 04, 2012 8:48 pm
1854 Brother pulling a 36 PD
viewtopic.php?f=5&t=12825
Wed Jul 04, 2012 11:22 pm
Speed I have a 18x4 Pearce hull I get 34-35mph at 3900-4000 rpms deep and shallow water depending on water conditions I can load it down and still run 30-32 easy I'm burning hardly any fuel by turning less rpms my stock prop I got to turn 4300 to get 34mph which is not good on a motor
In mud the Hopkins wheel has way more bite for jumpin up and getting out of a bad situation the stock prop I find myself working harder to get through pack tight lillies the Hopkins wheel chops them like a chainsaw both prop don't like sandbars which I think no prop does and I find that wheel is very tuff and doesnt ware down like them them stock props do but all around I find the Hopkins wheel works for me other may have different opinions and ideas but overall I'm turning less rpms still running good speed empty and loaded saving fuel and blow through bad situations with no problem
Thu Jul 05, 2012 7:05 am
What pitch hopkins
Thu Jul 05, 2012 7:10 am
What pitch/diameter and what prop? The cleaver? What all is done to your motor?
Thu Jul 05, 2012 8:29 am
I call BS runnin 35-35 MPH at that low of rpm
Thu Jul 05, 2012 9:33 am
What are you calling loaded?
Thu Jul 05, 2012 9:39 am
Post prodrive props
Thu Jul 05, 2012 11:14 am
Thu Jul 05, 2012 11:56 am
Let me borrow your prop, if it does what you say it will, their stock is about to go up.
Thu Jul 05, 2012 12:24 pm
you boys leave that boy alone. He obviously is typing on one of those keyboards with no periods or commas. Prolly got to typing and accidentally put in those speeds.
WC 1848 Bateau w/ 36 PD FPR
Thu Jul 05, 2012 12:26 pm
b s my rear end the wheel is a 13 pitch i was from the computer for awhile youll need more patience buddies im not scared at all to prove my theory i lunch out of amelia la boat every
weekend and loaded down i mean ice chest 4 people 180 plus lbs and a tube yeah i pull a tube with it
Thu Jul 05, 2012 8:31 pm
dam i leave away for a few hrs i get bashed speed all depends on ur rig and water condintions youll know that put it like this im pretty much pushing a tin can all 1/8 with a solid bottom thats why im getting those speeds
Thu Jul 05, 2012 8:34 pm
Post prodrive props
Hershey, send me that prop.
Thu Jul 05, 2012 8:35 pm
wish i can od i love that prop nobody believes but its a big difference between the 2 overall you gettin ur speed u want with less rpms and saving fuel while ur running u can trim up with this wheel and roll out with a pretty rooster tail
Thu Jul 05, 2012 8:52 pm
http://www.hopkinspropeller.com/mudprops/
trust me they a lil high and u dont get no warranty but their tuff and well worth the money
Thu Jul 05, 2012 8:56 pm
Post prodrive props
How much was yours?
Thu Jul 05, 2012 9:01 pm
it came with a motor i brought but the guy had just brought it brand new like 2 weeks before my purchase and talk very highly of it and every bit of it was true and he said it was around $480 but i called and talked to hopkins about their props they can pretty much cup and pitch the wheel to ur specs how you want just tell them ur situation and terrains u encounter and they will tune it just right but in mud they are flawless your passengers better hold on when you give it the juice
Thu Jul 05, 2012 9:20 pm
After all of the mods we do for a few mph, a prop is cheap for that kind of gains!
Thu Jul 05, 2012 9:21 pm
Thu Jul 05, 2012 9:22 pm
Thu Jul 05, 2012 9:28 pm
Heads are shaved 50 and ported and polished. Cam is 493f. 13 pitch Hopkins prop. Carb and exhaust. No work to to pistons....
18x4 Pearce hull all 1/8 crimped with cut back transom
That's my rig
Thu Jul 05, 2012 9:31 pm
What diameter prop, and which prop is it? I believe hopkins makes a few different style wheels. I know of a few guys that have run them, but are not seeing anywhere near the same results you are. Not with the little bit of motor work you have done, and not at those rpm's.
Thu Jul 05, 2012 9:53 pm
All I know is 13 pitch and the diameter you got me on that one but im in lOve with it and it works for me
Thu Jul 05, 2012 10:08 pm
How heavy their boats are???
Thu Jul 05, 2012 10:09 pm
Thu Jul 05, 2012 10:10 pm
Now see I know it was goin to come down to this I started not to answer ur rude self from the get go the guy ask are their any other props besides a pd stock prop which he got his answer rite ur question u ask me five times in a row is for you obivisily and you not getting no solid answer from me that's why I keep giving u the same answer call Hopkins like I did if get ur dam diameter test question you want like I did I was titled to my own opinion and you want to jump on me I'm not lookin for any trouble so move on I know all the specs on my prop I told you how it perform on my boat I don't have to lie come man we all grown men
Thu Jul 05, 2012 10:35 pm
lajalkfjdalksfasfkdj aslfkdaisdufasi;fjlakw efakljefklisfdluasil;fdja searfelw jrlkafjldusfilaus dflaksdjf lkejalfkjeflisduf asildfjaskldfjas d!!!
Thu Jul 05, 2012 10:39 pm
Me and the guy talk through pm he got all his info he ask me in a kind Way and I gave him his answer you the one making up the magic prop crap I gave you the name and pitch I didn't see knowthing magic about that you trying make me look like a fool
Thu Jul 05, 2012 10:40 pm
Ga gu ga chi gu ga ma cha awhh ya pa pa
Nahh pu ta ya
Thu Jul 05, 2012 10:43 pm
People have tried lots of different props from Hopkins, but I don't know anyone getting even remotely similar results as you. He has different props, different pitches, different diameters, can do different things with the cup. Reason I am asking questions is because, if what you say is true, then whatever he did with yours is what one of us would want to duplicate. Calling him and starting from scratch is expensive and has not yielded very good results for lots of others in the past, hence the reason people are recommending the stock prop as the best all around prop. If you actually knew what was done with your prop, you may be of some assistance, but just saying I have a hopkins prop with a 13 pitch that performs ridiculously better than any other prop anyone else has ever seen doesn't really do anyone any good...
Thu Jul 05, 2012 10:45 pm
Thu Jul 05, 2012 10:55 pm
You suck at the internet dude. :lol: Am I hurting your feelings? :lol:
I'm just asking what prop you are running. He asked what is the best prop, most would recommend the stock prop as the best all around prop. That's pretty simple, not much to add to that. Call PD, order a prop for a 36hp pd.
You recommend something else, but don't know what it is. A prop built by a custom prop shop, that can be built anyway you want it. The info you gave is not an answer to the guys question. Just a point in the direction down a long expensive road that many others have already been down, and are now back to using stock props. :lol:
Thu Jul 05, 2012 11:05 pm
Glad no came off the rocket chair now let's talk
I understand ur question completely but you and I know both know 1st it all depends on ur hull weight condition of ur hulls bottom etc..... Like I said I'm pretty much pushing a tin can that's why mine performs well for me and even when I talk to Hopkins he did give me the diameter and all specs on prop but I didnt write any of that crap down that's why I can't truthly answer ur question but I garuntee call their and ask all ur questions and make sure u have ur pen and paper ready and ask about the mud buster series but I'm pretty sure it's a 13x12 if I can remember straight ..
Thu Jul 05, 2012 11:12 pm
cron
