BlueShamu
 About to Get Outside the Box
Stay tuned....
| Wed Aug 31, 2016 11:36 am |
flint87
 Re: About to Get Outside the Box
| Wed Aug 31, 2016 12:02 pm |
brickgw
Subscribed....i got 2 of them laying in the garage that are worn out and running the stock 2 blade. Curious to see what's going on here lol
| Wed Aug 31, 2016 12:17 pm |
BlueShamu
Prop on the left....13" diameter splined Gen III hub.
Prop on the right....11" threaded/tapered bushing Gen II hub.
Going to attempt to make the Gen III fit a Gen II.
From there...I have plenty of prop to work with on another design altogether....contemplating ultimately ending up with a 3 blade Cleaver with maybe a 12" diameter.
Ultimately, probably a costly experiment.
| Wed Aug 31, 2016 12:23 pm |
teammarshmafia
Joined: Tue May 14, 2013 2:18 pm Posts: 478 Location: southeast, Louisiana
I'm gonna go out on a limb here and say blue is gonna try that gen 3 prop on his gen2. And the smaller one looks like a gdsd 3 blade. I forsee some rebroaching fixina happen
Sent from my SAMSUNG-SM-G890A using Tapatalk
_________________ Gen III Pro Drive with a JBP stage 2 pushin 18x54 madmancustom Jus nut up and grab a handful of throttle
| Wed Aug 31, 2016 12:26 pm |
banded-mallard
Troy, I haven't pulled mine before, but is it possible to take a gen 3 lower, remove the shaft and gear and swap it to a gen 2 lower? Thus keeping the splined shaft. The gearing would be different. But the second question would be could the bevel gear be removed from one and placed on the other? Thus giving you a gen 2 lower with a splined shaft rather than a threaded shaft.
| Wed Aug 31, 2016 12:46 pm |
banded-mallard
Because if that is possible, I would love to see a 3 blade 13" run on my Kawi with all that torque. Hell I'm running a 14P now at 4900-4950
| Wed Aug 31, 2016 12:47 pm |
BlueShamu
I don't know if the shaft diameters/length are the same throughout the length of the shaft and where they press into the gears. I screwed up and eventually threw my sheared shaft away. Wish I would have kept it in hindsight. I would give it to a machine shop and tell them make me one with hex flats on the end so I could play with and change out MB and GT props. I think the beveled gears and bearings are press fit.
| Wed Aug 31, 2016 2:18 pm |
BlueShamu
I've even given thought to weld overlay my threads and machine hex flats onto it....but, that would probably turn out bad. LOL
I'll just add.....threaded props are the devil!
| Wed Aug 31, 2016 2:19 pm |
SETx Longtail
Joined: Sun Sep 01, 2013 2:53 pm Posts: 3480 Location: Hardin County, Tx
I'm all in on this one. Very interested in what you come up with.
Hhmmmm, that splined 13p prop with some 7/8" threads... Oh the possibilities!
_________________ #CFFITR
-Custom pool noodle -stage 4 water wings
| Wed Aug 31, 2016 4:42 pm |
banded-mallard
I thought GTR and MB are a different rotation pitch
| Wed Aug 31, 2016 4:43 pm |
SETx Longtail
I was under the impression all these lawnmower boat motor mud prop things turned the same direction.
| Wed Aug 31, 2016 4:47 pm |
banded-mallard
They prob do, but don't know for sure.
| Wed Aug 31, 2016 4:59 pm |
Quackhead62
Joined: Fri Nov 30, 2012 7:47 pm Posts: 931 Location: Maurice,La
I like the way you are thinking Blue that would open up lots of things for the guy with the gen II threaded shafts. I'm going to stay tuned for sure.
_________________ Stage 2 36 HP Pro-Drive FPR W/ Bayou Boys Custom Skeg,Cave Plate,and Weed Cutter with MAC Exhaust Pushing a 17X54 Pro-Drive X-Series boat
| Wed Aug 31, 2016 5:09 pm |
cb5331
Nm, didnt read whole thread
| Wed Aug 31, 2016 5:23 pm |
Will
There's an old Evinrude left hand prop that's the same spline. Still don't know why someone hasn't tried one for running open water
_________________ Before the internet, the majority of the village idiots stayed in their villages.
| Wed Aug 31, 2016 5:54 pm |
banded-mallard
I'm still wondering if someone has tried to remove the gear off the shaft yet. Zimmer gear here in Baton Rouge prob has em or can get em. This would allow for ratio changes as well as prop changes.
| Thu Sep 01, 2016 4:19 am |
BlueShamu
I think I know why PD went 2:1 instead of something inbetween...your motor needs some gearing or some huevos to turn an additional 2 pounds of weight!
| Thu Sep 01, 2016 3:06 pm |
Quackhead62
| Thu Sep 01, 2016 6:06 pm |
cupnglide
Wow. I knew there had to be a difference. Didn't expect it to be that much.
| Thu Sep 01, 2016 7:26 pm |
BlueShamu
| Thu Sep 01, 2016 8:31 pm |
TPerkins
Joined: Wed Jan 02, 2013 12:59 pm Posts: 1793 Location: Clear Lake, Tx
I wonder how much weight difference there is between a power tech vs big blade vs hammer.
| Fri Sep 02, 2016 8:48 am |
BlueShamu
Ran a few beads over the splines using SMAW and 316L filler. Ran wide weave beads starting as far as I could get the rod into the opening and worked the rod out. Ran a pass around the circumference of the opening, over the ends of each pass to clean it up and get above the back side.
Next up...drill, tap and machine.
| Sat Sep 10, 2016 5:35 pm |
SETx Longtail
Need to do another one and drill it for 7/8..... Just sayin.
| Sat Sep 10, 2016 5:41 pm |
flint87
| Sat Sep 10, 2016 8:06 pm |
BlueShamu
| Sat Sep 10, 2016 8:12 pm |
banded-mallard
Well, did the welds hold?
| Tue Oct 04, 2016 12:03 pm |
BlueShamu
Been too dang busy on y'all's WKM's to do ANYTHING! Hope to have them finished, tomorrow.
| Fri Oct 07, 2016 9:38 pm |
banded-mallard
 , yep. me too. It a shame to say that the aftermarket clutch I bought several months back, is still sitting on my shelf. My boat prob has wasp nest the size of oranges in it. between work and my oldest with showcase baseball, I haven't had a chance to install it.
| Tue Oct 11, 2016 5:10 am |
BlueShamu
We shipping our six WKM's in the morning. But, we picked up a couple Delta BF's and a knife gate....you guys shouldn't wait ten years to work these things! LOL
| Wed Oct 12, 2016 8:06 pm |
