It is currently Sat May 10, 2025 1:47 am
Reply to topic  [ 11 posts ]
 Horrible noise coming from lower unit
Post Horrible noise coming from lower unit
Have a 4400 HDR, a month after I got it I noticed a minimal noise coming from the lower unit were the belt connects to the prop shaft. Then it went away I didn't hear it again until duck hunting a few days ago the sound came back and got very bad. It is almost older than the motor running. A seal has not gone out my shaft is still full of grease and I have taken the plug out before filling with grease every time. Could it be a bearing, bent shaft, ect...?
Mon Sep 19, 2016 3:03 pm
Post Re: Horrible noise coming from lower unit
Could be a bearing, loose taper lock, some random piece of something that's bouncing around while running (stick, bb, screw, nut, etc)... Does it make any noise when rotating by hand?
Mon Sep 19, 2016 3:14 pm
Are you feeling any vibration that you weren't feeling before?
1854 Prodigy DPE Level 3 HDR
Mon Sep 19, 2016 4:22 pm
Yes feel very large mounts of vibration and wen I turn it by hand I can hear it not as loud .
Mon Sep 19, 2016 4:34 pm
Bad bearing.
Mon Sep 19, 2016 4:40 pm
I've seen plenty of those bearings with normal greasing last well over 500 hours without issue (the one we have now was past 800), so I'm hesitant to say that's the problem, but it's possible. Take it to your dealer if it's under warranty and make it their problem.
Mon Sep 19, 2016 4:41 pm
Take it in if under warranty, or pull the outdrive and take a look if it's not.
Sent from my SAMSUNG-SGH-I537 using Tapatalk
Mon Sep 19, 2016 4:43 pm
I talked to mudbuddy and they said its under warranty so I don't think it will be a big deal. And thank y'all for the help.
Wed Sep 21, 2016 10:56 am
Refurbishing a Prodrive
Wed Sep 21, 2016 1:07 pm
damn mudbuddy
Mon Oct 10, 2016 6:47 pm
Mon Oct 10, 2016 8:49 pm
