It is currently Sat May 10, 2025 4:42 am
Reply to topic  [ 30 posts ]
 Problem with PD reverse
Post Problem with PD reverse
I am having trouble with my lower unit turning to go in reverse. I checked the torsion knob, hydraulic fluid, and I can hear the pump working but the lower unit always has trouble spinning aroumd. The only way I can get it to turn is to trim the engine up and down and hit the reverse button back and forth a bunch of times to where it eventually slowly catches and spins around.
Any help/advice would be appreciated.
Tue Nov 15, 2016 9:10 pm
Post Re: Problem with PD reverse
Make aure youre relay is working right
I gave up mud motors
Wed Nov 16, 2016 4:58 am
The Pro drives use a Shallco rocker switch that carries the load, No relays for auto reverse, If you have a switch issue where when you press the button nothing happens then it eventually catches, your switch slider is worn.
If you are hearing the pump spin with no action on the ram, make sure there is indeed enough fluid and check for leaks. A pump turning with no rod action almost always indicates air in the system.
Wed Nov 16, 2016 6:15 am
Thats the old switch t marcus.
Depending what year his motor is there is a relay on the pump. Its basically a winch relay. Mine went out and it was doing similair to what he said
Wed Nov 16, 2016 7:05 am
Wed Nov 16, 2016 11:51 am
First thing you need to do is make sure the battery is fully charged. Many times the battery will slowly weaken and then the trim or reverse on a PD wont work due to loss in amps and all that is needed is a fresh charge. Depending on what you're doing the charging system on the Briggs doesn't always keep it topped off.
Wed Nov 16, 2016 1:27 pm
Washer placement.
Wed Nov 16, 2016 2:27 pm
Thanks for the responses.
Checked the battery, it's fine. Have an onboard charger. All electrical leads seems to be fine.
I greased the shit out of it and cleaned up some of the old grease. Still no dice. I can get it to turn 180 to reverse if I pull on the lower unit while hitting the button and the hydraulics helps a little. It turns to go back in forward by itself with no problem at all. 2013 setup..
Wed Nov 16, 2016 4:21 pm
Got to be something in the actuator. I unbolted the end of the ram and it's still doing the same thing. Moving very slowly in reverse.
Wed Nov 16, 2016 4:27 pm
You unbolted it from the half moon gear and it won't stroke?
If so, several things to troubleshoot. Make sure you have fluid in your hydraulic reservoir. Then, try bleeding your hydraulic lines.
Can't remember if 2013 was a single or dual pump...I think single. If single, selector switch could be bad. Or, ram unit.
If double, swap out hydraulic hoses for trim with your reverse. In fact, you can probably do this with the single unit. If nothing else, swap the reverse/forward hoses and see if it acts the same in the opposite direction or if it's still bad in the same direction.
Wed Nov 16, 2016 5:45 pm
Blueshamu
Yes. When I hit the reverse button it retracts very slowly, sometimes catching and acting normal half way retracted but most of the time it just barely retracts. I'm pretty sure it's a bouble pump as it has two hoses per actuator, trim and reverse. I'll try swapping the hoses around tomorrow.
Thanks to all.
Wed Nov 16, 2016 8:44 pm
Depends on the year but they got some bad rams the piston would cock in the cylinder and nick it went thru 2
driving a gd in ur lake
and i aprove this message
Wed Nov 16, 2016 9:58 pm
Thu Nov 17, 2016 5:10 am
Yep, sounds like a bad seal and it's leaking around.
Thu Nov 17, 2016 6:10 am
37 PD EFI FPR 18x48 Tiller
SOLD -- 27 PD FPR 16x36 Skiff
Thu Nov 17, 2016 11:13 am
Prove it.
Thu Nov 17, 2016 11:39 am
Thu Nov 17, 2016 11:49 am
:lol:
Thu Nov 17, 2016 11:50 am
:lol:
Thu Nov 17, 2016 11:51 am
Clay is a first class asshole!
Thu Nov 17, 2016 11:56 am
Thu Nov 17, 2016 11:59 am
:mrgreen:
Thu Nov 17, 2016 12:00 pm
Thu Nov 17, 2016 12:32 pm
:lol: :lol: :lol:
Thu Nov 17, 2016 12:39 pm
:lol:
Thu Nov 17, 2016 1:58 pm
Thu Nov 17, 2016 8:54 pm
Just had a similar issue today, the cylinder would retract fine, but would not extend without assistance. We swapped the hydraulic cylinder out as a test and it worked like new ( bad seal). Moisture/contaminated fluid will destroy the seals.
Thu Nov 17, 2016 11:06 pm
Fri Nov 18, 2016 6:35 am
Junk
Sat Dec 03, 2016 1:00 am
Users browsing this forum: No registered users and 130 guests
