It is currently Fri Jul 18, 2025 4:33 am
Reply to topic  [ 23 posts ]
 Pop Rivets
Post Pop Rivets
What size are the pop rivets that they use to hold down the floor on a gatortail boats? I drilled mine out to clean paint my entire boat. thanks in advance.
Mon Jul 27, 2015 9:02 am
Post Re: Pop Rivets
Not sure but I would go back with 3/16x3/4 or 1" stainless rivets.
They should be 3/16 though.
Sent from my beeper
Mon Jul 27, 2015 9:06 am
Post Re: Pop Rivets
Make sure to get SS ones.
I always used 3/16"x3/4" SS rivets.
Mon Jul 27, 2015 11:09 am
Post Re: Pop Rivets
Why not aluminum rivits?
Sent from...wait, Where am I?
Mon Jul 27, 2015 11:20 am
Post Re: Pop Rivets
stainless are stronger.
Mon Jul 27, 2015 11:36 am
Post Re: Pop Rivets
Mon Jul 27, 2015 11:37 am
Post Re: Pop Rivets
thanks guys!
Mon Jul 27, 2015 11:39 am
Post Re: Pop Rivets
I'm new at metallurgy, will stainless react with aluminum like regular steel does?
Mon Jul 27, 2015 12:14 pm
Post Re: Pop Rivets
Yup, Top metal will hold but mushroomed end will wallow out and loosen.
Mon Jul 27, 2015 3:33 pm
Post Re: Pop Rivets
Mon Jul 27, 2015 3:48 pm
Post Pop Rivets
Yes they will if they stay wet for a extended period of time. The stainless piano hinges on the rear hatch and livewell of my bass boat just had to have the rivets replaced. The livewell hinge get wet from throwing in fish and the rear gets wet from hammering down in reverse. All of these rivets were corroded and broke right where the rivets contacted the hinges.
1644 WeldCraft / 27 GDLT
Ranger R71 / 125 Merc
Mon Jul 27, 2015 4:36 pm
Post Re: Pop Rivets
However, it's the aluminum that corrodes and using the bigger SS rivets will do the job.
Mon Jul 27, 2015 4:46 pm
Post Re: Pop Rivets
Galvanic corrosion 101....the farther apart on the galvanic series chart, the more aggressive the corrosion on the less noble material. The stronger the electrolyte between the two metals, add heat, add electrical current....the more aggressive the corrosion. Just the metals in contact with each other without an electrolyte will not cause galvanic corrosion (crevice corrosion, yes...galvanic, no).
Mon Jul 27, 2015 7:50 pm
Post Re: Pop Rivets
Tue Jul 28, 2015 11:14 am
Post Re: Pop Rivets
According to kibb's chart it says never recommend.
Tue Jul 28, 2015 11:50 am
Post Re: Pop Rivets
you better not be standing up when you get the price on f'n SS rivets and the amount your gonna need.
Tue Jul 28, 2015 12:07 pm
Post Re: Pop Rivets
Tue Jul 28, 2015 12:20 pm
Post Re: Pop Rivets
According to that chart galv rivets would be better
Tue Jul 28, 2015 12:24 pm
Post Re: Pop Rivets
where can I get them at? ebay has them for 12 bucks for 25. that's 3/16 x3/4 inch big flange.
Tue Jul 28, 2015 12:27 pm
Post Re: Pop Rivets
Tue Jul 28, 2015 12:40 pm
Post Re: Pop Rivets
Tue Jul 28, 2015 12:41 pm
Post Re: Pop Rivets
yup, big difference. I'm debating on cutting my floor out to repair a broken rib. When my clutch went out, this guy in a 24' hanko pulled me in and beat the shit out of my boat. Now I have a slight flex in one spot of the floor. I also debated on putting a cross brace across the floor to help support, but I hate rigging shit. Like to do it right, thus me considering riveting my floor back rather than fully welded out like it is now.
Tue Jul 28, 2015 12:48 pm
Post Re: Pop Rivets
Tue Jul 28, 2015 3:51 pm
Users browsing this forum: Majestic-12 [Bot] and 108 guests
