It is currently Mon Jul 21, 2025 12:53 am
Reply to topic  [ 12 posts ]
 Docking heads
Post Docking heads
Does anyone know how much, or what most are docking the head's on a 25hp kohler? "hydrolic lifter's"
Thanks
1848 DeadFowl pushed by a Stage 4 Delta powered MB HDR (JBP dusting)
Wed Aug 04, 2010 7:59 am
Post Re: Docking heads
i wouldn't go any more den .030 on de decking and don't forget to bleed down u'r lifters!
Wed Aug 04, 2010 8:10 am
what do you do to bleed down the lifter's? Just put it at tdc and touque the rockers to 100 inch pound's?
30 huh, arnt most going 60? Or only 30 because of the hydrolic lifter's?
Thanks
Wed Aug 04, 2010 9:00 am
I give you permission to go .120 on them heads................................ Just jokin, .030 is a good deal.
BUCK OFAMA
Sun Aug 08, 2010 5:25 pm
To bleed the lifters you apply pressure to the plunger of the lifter until the reservoir is empty. Or better yet just buy new lifters. When I did my heads I had 2 lifters stuck and that was at 47 hours. The kohler manual says you don't have to prime the lifters before install, but be prepared for some crazy tapping for first few minutes after rebuild.
Mon Aug 09, 2010 1:26 pm
Mon Aug 09, 2010 1:36 pm
Also, I only shaved my heads down .020, added ss valves, ported, polished, and shimmed valves up .060. Now my compression is 184/185. That is as high as I want to go, cause I want this thing to last.
Mon Aug 09, 2010 1:39 pm
The stock 30 heads took my motor to 185 comp. Was at 150 before.
Mon Aug 09, 2010 1:42 pm
Yea I would of went that route, but I only paid $160 for all the headwork.
Mon Aug 09, 2010 1:45 pm
Yeah, thats a good deal. You can find the 30 heads on ebay with new valves and springs for about 180. They are a lil over 200 just for the heads if you go through a kohler dealer.
Mon Aug 09, 2010 1:47 pm
Mon Aug 09, 2010 2:53 pm
Mon Aug 09, 2010 3:01 pm
Users browsing this forum: Google [Bot] and 107 guests
