It is currently Sun Jul 20, 2025 10:02 pm
Reply to topic  [ 2 posts ]
 Frog spit
Post Frog spit
I have a gallon of frog spit...and i was wondering if its worth putting on? How does it hold up under normal use, and will it just cause me problems when it starts to come off? I would greatly appreciate some feedback!! :)
Mon Sep 20, 2010 2:40 pm
Post Re: Frog spit
we use it a lot....sand or rough up the surface with 80 grit...wash down with alcohol ( not #7 )...mask of where you do not want it...like about 3" above the bottom on the sides...mix up about 1 /4th of your mix and start at the back of the boat...work your way to the front...i use a 3 to 4" throw away bush..acts like a squegee.....mix up the next batch...do the same...it flows like glass....good luck ...call me if you need more info...glad to help...semp-fi
lamarr....dba... www.floridamudmotors.com..321-243-1035
Mon Sep 20, 2010 6:16 pm
Users browsing this forum: No registered users and 118 guests
