It is currently Sun Mar 29, 2026 1:43 pm
Reply to topic  [ 20 posts ]
 Bore & threading
Post Bore & threading
Anyone know what kind of tool used to bore a prop? From 3/4 Hex to 7/8 threaded.
36hp Pro-Drive with EVT exhaust pushin a 17x42 custom skiff
Thu Dec 09, 2010 6:50 pm
Post Re: Bore & threading
I wouldn't be surprised if there's not enough material there to get the proper depth threads. Assuming, the hex is measured on the flats and not the points.
1644 WeldCraft / 27 GDLT
Ranger R71 / 125 Merc
Thu Dec 09, 2010 7:41 pm
that right, the hex is measured from the flats, so that doesnt leave enough left to thread
Thu Dec 09, 2010 8:36 pm
Thu Dec 09, 2010 8:48 pm
if ya run a tap in it if it cuts the threads at all they will not be any in the corners because that diam. is not right
driving a gd in ur lake
and i aprove this message
Thu Dec 09, 2010 8:59 pm
Thu Dec 09, 2010 9:04 pm
You don't bore it to 7/8". You bore it smaller then, cut the threads. The threads are 7/8" at the deepest part in the hub.
Thu Dec 09, 2010 9:31 pm
Measure the hex hub, point to point and get back with us.
Thu Dec 09, 2010 9:35 pm
Kibb, Point to point i got 7/8. Square to square i got 3/4. Which leaves 1/8 of an inch for the threads ??
Thu Dec 09, 2010 9:44 pm
Thu Dec 09, 2010 9:49 pm
It wont work as Craig stated. You wont have threads all the way around. Even where the flats are you wouldn't have enough thread depth, but go ahead and try it and tell us how it turns out. We know you are going to do it anyway.
Thu Dec 09, 2010 9:54 pm
Thu Dec 09, 2010 9:55 pm
Thu Dec 09, 2010 9:58 pm
Depends on TPI.
Thu Dec 09, 2010 10:00 pm
Thu Dec 09, 2010 10:02 pm
Threads per inch. The TPI would have to be identical so you would be cutting the old ones down and deeper.
Thu Dec 09, 2010 10:05 pm
Thu Dec 09, 2010 10:08 pm
1/8" will be a lot to cut at one time with a hand tap, even if they are the same. Find a chart online and drill the threads out to spec and tap from there.
Thu Dec 09, 2010 10:20 pm
better make all your holes and threading straight or you are going to have some horrible vibration going on and things coming apart on ya. Buy a new prop and save the money you will be spending if that prop ends up tearing stuff up cause of bad vibration.
Thu Dec 09, 2010 10:37 pm
I had Baggy convert a hex bore prop to a taper bored & keyed and ended up costing as much as a new prop. The had to bore it, install and weld an insert and then do the machine work. So to answer your question YES it can be done, just ain't real cheap.
Tue Dec 14, 2010 4:52 pm
