It is currently Wed Dec 17, 2025 6:10 am
Reply to topic  [ 21 posts ]
 Any way to keep PD weedless?
Post Any way to keep PD weedless?
Running thru matted tules today, and was thinking there has to be a way to keep that chit from wrapping around the shaft.
Anyone do this yet?
32 PD with EVT cam, decked heads, shaved pistons and not enough sense to leave things alone!
Thu Dec 23, 2010 4:36 pm
Post Re: Any way to keep PD weedless?
Due to the outboard style design, if you are running on step, then you have to just trim up all the way, then back down.. If you are just idleing, then just put pressure on the handle, and tilt motor.
Hope that helps...
Uncle J
Thu Dec 23, 2010 4:41 pm
cant help myself :lol: should have bought a gator tail
Thu Dec 23, 2010 4:56 pm
Uncle J - thanks for the reply. I'm not talking so much about the mass of vegetables that builds up around the lower unit. I want to find a way to keep the fibers from filling the gap between the shaft nut and the wedge at the front of the prop. It wraps up tight as a knot in there and has to be cut out. I think I saw a stick on blade for the lower unit of an outboard in Cabelas way back, I guess I'm kinda thinking of something like that.
Thu Dec 23, 2010 4:57 pm
Thu Dec 23, 2010 4:58 pm
O.. I see.
Shooter, make sure to clean that gap when ever you think about it.
BAHAAAAAA !!!
you can go through more grass, but can back up in MUD... Is it a mudmotor or grass?
Thu Dec 23, 2010 5:00 pm
Something like this:
http://www.quickwater.com.au/content.htm
Wonder if it'd work on a Pro-Drive
Thu Dec 23, 2010 5:15 pm
So,
You are saying that it actually wraps around the prop? if so, sharpen it.. LOL.
It looks as if that can be set, so I dont see why it wouldnt work.
Good luck.. Let me know what the outcome is..
Jason
Thu Dec 23, 2010 5:19 pm
OF SUBJECT..
Shooter, you have good taste !!! That Avatar and a Prodrive..
Thu Dec 23, 2010 5:20 pm
To be successful, you must decide exactly what you want to accomplish, then resolve to pay the price to get it.
Thu Dec 23, 2010 5:53 pm
Thu Dec 23, 2010 6:03 pm
Thu Dec 23, 2010 6:45 pm
Don't worry about it. Just run it. Mine has grass in the gap all the time and I have run it that way for over 3 years. It can't hurt anything.
18x48 Charles Leonard / 36PD
Thu Dec 23, 2010 9:33 pm
Thu Dec 23, 2010 9:36 pm
Fri Dec 24, 2010 12:31 am
Fri Dec 24, 2010 2:32 am
mine has grass/trot line/fishing line always in it for months at a time before i cut that crap out. Its never hurt anything! Run it like its meant to be...
Fri Dec 24, 2010 4:37 am
Fri Dec 24, 2010 8:53 am
I would recommend to cut it out from time to time. It's pretty easy to keep up with. That is what I do.
Crisis defines character
Fri Dec 24, 2010 12:17 pm
I do cut it out every now and then at the house. I don't run that type of veggies but occasionally I get into some flooded fields and the grass will ball up while slow rolloing. I just lift the motor and gass it. Will usually throw that ball off. Don't know of any way to keep it completely clean. But I have never had any issues that i know of.
Fri Dec 24, 2010 12:52 pm
Mon Dec 27, 2010 8:24 am
