It is currently Mon Mar 30, 2026 12:30 am
Reply to topic  [ 8 posts ]
 New to mud...need advice
Post New to mud...need advice
I currently own a 1448 sea ark modified v. Its a welded hull. I need to know if a long tail will work on the boat and if so what size hp I need to be looking for. The boat is rated for a 30hp outboard. Typically, its me, another idiot, decoys and gear. So around 500 pounds if I had to guess. Any and all information would help. Thanks in advance.
Tue Jan 04, 2011 5:06 pm
Post Re: New to mud...need advice
id say a 23 hp lt will do good
Running a homemade 14x38 skiff with the good ole' 13 h.p Go-Devil longtail
Tue Jan 04, 2011 6:16 pm
X2 agreed
18x40 Gatortail skiff
35 GT
Simple and straight forward.
Tue Jan 04, 2011 6:26 pm
I have a 27 hp beavertail on my 1448 mod v. I like it a lot. There's enough power to be relatively quick and it's still light enough to not HAVE to put pods on (however, I am going to put them on after season mainly to help load carrying). If I had to do it all over again I would pick the same set up but a longer boat (1648 or 1644)
Tue Jan 04, 2011 6:38 pm
a mod v wont perform as well as the flatbottoms.
Tue Jan 04, 2011 8:47 pm
x2 This past weekend, me and the guys i hunt with on here were running and he and i both beached it on a mud flat, he had a mod v i had a flat bottom, i was running two people and all gear, he had himself and pierow. I was able to idle off the flat, he was diggin in with his bow and fighing it the whole time.
14 by 44 Weld Craft powered by a 20hp. go devil longtail
Team Arc Angel Bowfishing
Tue Jan 04, 2011 9:39 pm
Depends if it is a tall or short transom? SHort Transoms do wonders with the LT's, talls tend to make it harder to keep the prop ride just below the surface!
Tue Jan 04, 2011 11:33 pm
Thanks for the info. What about a 27hp?? Would that be too heavy??
Wed Jan 05, 2011 9:34 am
