It is currently Thu Jul 17, 2025 2:35 pm
Reply to topic  [ 9 posts ]
 12hp copperhead remote fuel option?
Post 12hp copperhead remote fuel option?
So I'm looking into buying a new 12hp copperhead for my 1548. However 2.7 quarts of fuel won't get me very far. I plan on using it to run the wapsi river, so my question is to any of you copperhead owners. Whats it take to install a remote tank?
Mon Feb 28, 2011 8:49 pm
Post Re: 12hp copperhead remote fuel option?
does your engine have an alternator? if not you can pulse pump it. like the mikunis that are on most small engines. i just put an e pump on my 9hp lifan, it has a 3 amp alternator. http://www.affordablegokarts.com/ try this link for some ideas.
Mon Feb 28, 2011 9:31 pm
Garjacker, these little motors don't have alternators. So he does have to use the pulse pump option.
You need to get a diaphram fuel pump. The kind that pulses off crankcase pressure.
This is something that you would need.
This may help you out.
If you still need help, give Gil a call. He has a remote fuel tank setup on his 12hp.
Copperhead 12Hp SD on 1442 Alweld
Tue Mar 01, 2011 8:18 am
Tue Mar 01, 2011 4:53 pm
Cool, thanks for the info fella's!
Tue Mar 01, 2011 5:31 pm
You would be amazed how long one will run on a tank.
My 13 honda can run all weekend on a tank and a half.
Carry a 5 gallon can with you and refill it whenever you get low.
How long of a run are makin?
Tue Mar 01, 2011 8:43 pm
we will be runnin this motor for a few hours at a time. I'd just a soon have a remote tank, because the river I run has very swift current with lotsa snags in it. I could just see runnin outta go go juice at the wrong time and endin up in one a those snags.
Tue Mar 01, 2011 9:52 pm
hey did you check out the copperhead website they have a remote set up.
Wed Mar 02, 2011 4:48 am
Life is like rolling the Dice
Thu Mar 03, 2011 8:49 pm
Users browsing this forum: No registered users and 131 guests
