It is currently Mon Jul 14, 2025 10:53 pm
Test run results dguidry mods!!!
jordy
Joined: Thu Mar 11, 2010 8:25 pm Posts: 1588 Location: South Louisiana
 Re: Test run results dguidry mods!!!
after reading i do not think you would hit 35 mph dguidry, sorry buddy, if that was the case i will TRADE my 35 horse right now for a 23.....anyways i read you are still running your stock muffler, whenever i modded my motor they guy that did the work told me to put on a performance exhaust asap b/c it flows better and keeps the valves cool. i planned to leave the stock one on for a while but he said i would burn a valve, im not sure how accurate that is maybe one of these mechanics savvy guys can chime in on it, but its something you might want to do right away b/f putting too many hours on your mods.
Wed Mar 30, 2011 6:46 am |
dguidry
Joined: Tue Jun 29, 2010 1:20 pm Posts: 11166 Location: Cecilia, LA
Coefficient of slip as in "prop slip"!! Sorry misunderstood the posts on this. Don't know much about this. How does the coefficient change with increased rpm over fixed throttle range?
_________________ Formerly:1648 Homemade Cypress Crawfish Skiff GTR23 Performance Cam and Heads; 17x46 Gator Tail with 35GTR and Hoyt's cam;s Currently: 17x48 Gator Tail with XD40 EFI. “Wisdom is not just expertise. It is knowing how much of various areas of expertise you need to know in order to make the decisions that the world needs and that you want to do,” Columbia University President Lee Bollinger.
Wed Mar 30, 2011 8:24 am |
dguidry
Here is a site with calculator that caculates slip coefficient. It's a functioned pitch, speed, rpm and gear ratio:
Wed Mar 30, 2011 8:45 am |
dguidry
Yesterday tested my boat with following load 24.8 mph at 3300 rpms
Conditions: ripples and mild wind
Me 258 lbs Trolling motor 48 ice chest with 10lbs ice 3lbs beverages 6 gal fuel 2 batteries Tool box 5lbs Cabella chair pod Tackle box
Sun Apr 03, 2011 8:50 am |
pooldoo73
Joined: Tue Jan 25, 2011 5:47 pm Posts: 886 Location: Plaquemine
If u input the numbers dguidry posted about speed into the prop calculator, you actually get a -30 percent slip. This is with 27mph at 2500rpms. Also with a 12 pitch prop and 1.2 gears. I'm sure everyone already knows you can't have a negative slip except for dguidry. Wut a mullet.
And then u get a 20% slip with his newest numbers. Wut a difference a couple hundred Rpms means.
_________________ 18'x54"CC Hanko/ 36PD
Sun Apr 03, 2011 7:24 pm |
benelliman
Joined: Wed Jan 14, 2009 10:54 am Posts: 532 Location: Livonia, La.
My skiff runs a solid 30mph at 3900 and 28mph at 4100.I think it has something to do with more efficent use of the prop. How do you know if your prop is slipping?
Sun Apr 03, 2011 7:39 pm |
dguidry
Sun Apr 03, 2011 7:43 pm |
dguidry
Sun Apr 03, 2011 8:04 pm |
Users browsing this forum: Google [Bot] and 89 guests |
