Durty
Joined: Tue Apr 05, 2011 11:27 am Posts: 91 Location: San Antonio, TX
 GDSD Lower Bushing Replacement
Manual says to use a sawzall to cut lower bushing out if you don't have their tool. (I do not have their tool and do not intend to purchase). Is the sawzall idea the best yall have found? Seems like very little margin for error. Plus, those sawzalls aren't the most precise tools... I wonder if a dremel could do the job. Or is there a way to pop it out the back?
_________________ 23 gdsd/1542 alumacrap
| Tue Apr 26, 2011 9:32 pm |
autogateman
Joined: Thu Sep 16, 2010 10:32 pm Posts: 4036 Location: Gonzales La
 Re: GDSD Lower Bushing Replacement
they are half right. use the sawzall, but use a wood blade. it will easily cut the bushing without cutting into the housing. works perfectly.
| Tue Apr 26, 2011 9:34 pm |
Durty
use a wood blade on a brass bushing? Seems like I could do more damage with a wood blade with less tpi. please explain if you don't mind
| Wed Apr 27, 2011 6:59 am |
Gigafowl
The bushing is softer material....
The wood blade cuts the bushing but not the steel housing....
That's what he was tellin you anyway --- or --- just take it to GD and let them do it....
| Wed Apr 27, 2011 7:20 am |
autogateman
Woof blade has higher tpi
| Wed Apr 27, 2011 7:40 am |
Duckdon
Joined: Sat Apr 24, 2010 3:32 pm Posts: 407 Location: Chugiak, Alaska
You can use just a hacksaw blade if yoru worried about damage to the inside of the tube housing. Personally, I would use a metal blade of a sawzall and take it easy. Hold the saw flat with the surface of the bushing and go slow. Good light would be another idea. Duckdon
| Wed Apr 27, 2011 8:22 am |
Durty
Generally speaking, wood blades have less teeth per inch than blades that are made for cutting metal. This.is a general rule of thumb. The more teeth per inch, the easier it is to control the blade because its not bouncing off the material as much. That's why when you suggested using a wood blade I was confused.
| Wed Apr 27, 2011 9:42 am |
autogateman
i suggested the wood blade because it wont cut the steel. you asked for advise and i gave you the proven method.
| Wed Apr 27, 2011 11:45 am |
Durty
Understood. Have no desire to prove anyone wrong. Just trying to fully wrap my brain around this project.
| Wed Apr 27, 2011 11:49 am |
autogateman
dont worry, you not gonna mess anything up. put the wood blade in the bushing, cut it till it rubs the housing. do this in three places and you can pull out the bushing. i learned to use the wood blade because i was out of metal blades, and it worked so well and fool proof that it is the way I recommend everyone to do it. if you use the metal blade and accidentally cut the housing the new bushing wont fit/seal correctly.
| Wed Apr 27, 2011 11:54 am |
Durty
Ah. That makes a lot of sense. That's what ill do. Thanks again.
| Wed Apr 27, 2011 4:33 pm |
pooldoo73
Joined: Tue Jan 25, 2011 5:47 pm Posts: 886 Location: Plaquemine
Could u pull it out wif a slide hammer? Or is the hole too small to get the teeth into to pull it out?
_________________ 18'x54"CC Hanko/ 36PD
| Thu Apr 28, 2011 6:47 am |
fishon!!
Joined: Tue Nov 17, 2009 6:52 pm Posts: 339 Location: Capital Shity, LA
maybe start your cut with a metal blade, then switch to a wood blade
_________________ Save your confederate money, cause the south WILL rise again homebuilt 11 HP greyhound LongTail -1436 flatbottom
| Fri Apr 29, 2011 12:11 pm |
koda4u
Joined: Wed Jan 21, 2009 10:43 am Posts: 72 Location: Tennessee with a Louisiana wife...
Cant someone show pictures and steps to replace the lower seal on a gdsd 35 . thanks and also caN you buy the seals from auto parts stores?
_________________ 18x54 CC Gatortail Huntdeck w/35GTR MM double barrel X Go Devil 16x56 w/35 SDGD -sold
| Thu Sep 08, 2011 11:29 am |
deltaduckmaster
Seal problems!! Ummmmmm
_________________ 17x48 extreme stage 2 GTR 20X60 DUAL RIG BOWFISHING ADDITION http://www.scalesandtailsbowfishing.com
| Thu Sep 08, 2011 11:35 am |
koda4u
I just want to know how to replace them before season starts. thanks
| Thu Sep 08, 2011 11:44 am |
MaXXis85
No way!
| Thu Sep 08, 2011 12:02 pm |
waterfowlwarrior
Koda, You can find detailed instructions in the updated owners manuals. Remember that GDSD and GDLT's are a bit different. http://www.godevil.com/documents/Surfac ... mplete.pdf
| Thu Sep 08, 2011 12:05 pm |
take'emgator
Joined: Mon Oct 19, 2009 6:38 pm Posts: 10201 Location: SETX
This cant be a gdsd!
| Thu Sep 08, 2011 1:15 pm |
Robn1020
Joined: Mon Feb 16, 2009 6:09 pm Posts: 4232 Location: Cypress, TX
Dude, you live in san antonio. Bring it to bart baker down there. He'll fix you up. How old is the motor?
| Thu Sep 08, 2011 3:50 pm |
JIMMY W
Joined: Tue Jan 13, 2009 8:02 pm Posts: 4534 Location: South Louisiana
Yeah buddy
_________________ 17/54 GT EXTREME Center Console, Huntdeck w/ GTR 35
| Thu Sep 08, 2011 4:47 pm |
MaXXis85
| Fri Sep 09, 2011 7:36 am |
