It is currently Mon Jun 23, 2025 10:07 am
Reply to topic  [ 7 posts ]
 cam adjustment
Post cam adjustment
i bought swampsnypers motor and when i pulled the crankcase cover off i noticed the cam was one tooth over from the dot on the crank. also he said he had the gov arm pulled tight with a spring why do they do that? with stock carb
Tue May 17, 2011 8:21 am
Post Re: cam adjustment
ive never heard of the cam thing
Tue May 17, 2011 2:14 pm
When you have a cam built for the smaller kart racing motors, a lot of them are adjustable. They really try to tweak those things to get their powerband exactly where they want it. I wouldn't even know where to start with one of these motors and don't really see the need to try. They cams we are buying are pretty well set up to make power in the range that we want them to already.
What cam was in the motor? If it were a cheetah, I could see wanting to move the powerband down in the rpm range.
Tue May 17, 2011 4:03 pm
Probably was installed that way by accident. Cam timing can be adjusted with the grind as well.
Tue May 17, 2011 8:26 pm
Looks to be a stock cam
Tue May 17, 2011 9:56 pm
If it is a BPS cam the first run of them where improperly marked.
Sun May 22, 2011 8:04 pm
This may be a broad question, but about how many rpm's does the peak tourque change per timing tooth?
Mon May 23, 2011 7:06 pm
Users browsing this forum: Google [Bot], Majestic-12 [Bot] and 134 guests
