It is currently Fri Jul 18, 2025 5:54 am
Reply to topic  [ 18 posts ]
 PD 32
Post PD 32
Recently got a new phowler 1848 to go with my PD 32. After first time out only got 21 mph out of it( not too happy). Wanting to do some mods but not sure what will be best.
Thu Jun 30, 2011 7:58 pm
Post Re: PD 32
You need to make sure your motor is running correctly before you start adding mods. What rpm's are you turning WOT? What kind of shape is your prop in? You should defiantly be getting better speeds
1848 Prodigy
35 GTR
Thu Jun 30, 2011 8:35 pm
Post Re: PD 32
Something ain't right, you should be runnin 26-27. What are your WOT rpms in neutral?
"Insert gay tapatalk signature here"
Thu Jun 30, 2011 8:38 pm
Post Re: PD 32
Thu Jun 30, 2011 8:40 pm
Post Re: PD 32
Rpm in neutral is 4020. Prop is new only one tiny nick in it
Thu Jun 30, 2011 8:50 pm
Post Re: PD 32
You didn't put a long shaft motor on a short transom boat did you? Or vice versa
Have you ever run a mud motor?
Thu Jun 30, 2011 8:55 pm
Post Re: PD 32
My old boat was a 16inch transom the new one is 21 inc, so i bought the shaft extension kit for the motor. And yes ive had the motor for 3 years now i think
Thu Jun 30, 2011 8:59 pm
Post Re: PD 32
You need to do a compression test
Thu Jun 30, 2011 9:02 pm
Post Re: PD 32
Ya i thought i should be getting more than what i am, are my rpm ok? what should it be running in neutral?
Thu Jun 30, 2011 9:05 pm
Post Re: PD 32
4250 or so
Thu Jun 30, 2011 9:08 pm
Post Re: PD 32
Have the compression test done, if the cylinders are off or low, have a leakdown to see if your valves are seating well. If not, then get some headwork done to clean it up.
Fri Jul 01, 2011 5:09 am
Post Re: PD 32
Fri Jul 01, 2011 7:56 am
Post Re: PD 32
So i finaly got the motor to a shop and had to have new head gasket and rocker seals replaced. Now that i got it back it it sounds and runs good only until I open the throttle up. It will only get to about2800 rpms and it sounds like its hitting a governor. If i gradually open the throttle i can get it to about 3800. I dont know what they adjusted on it but it not even close to rpms i was getting ANY IDEAS?
Sat Nov 19, 2011 9:35 am
Post Re: PD 32
At idle pull one plug wire. If it stays running pull the other one if it dies you may need new diodes.
Sat Nov 19, 2011 11:46 am
Post Re: PD 32
Sounds like the mechanic reset your governor to low. Standing on the right side of the boat and motor there wil be a horizontal phillip head screw right over the mufflers exhaust tube leaving the head. Turn it clock wise to increase your rpm's ( out of water 4250) .
Sat Nov 19, 2011 1:00 pm
Post Re: PD 32
ya i have had the gov. srew tightend all the way and still the same ol story. Any other ideas Could it be carb problem? is there adjustments for that?
Sat Nov 19, 2011 2:50 pm
Post Re: PD 32
Could valve spacing cause this to happen?
Sat Nov 19, 2011 2:53 pm
Post Re: PD 32
Could be as simple as your choke or throttle linkage travel being off. Though the trottle travel wouldn't really fit the hitting the govern. symptons
Sat Nov 19, 2011 3:24 pm
Users browsing this forum: No registered users and 91 guests
