It is currently Fri Apr 10, 2026 4:35 am
Reply to topic  [ 19 posts ]
 what boat should i be looking at
Post what boat should i be looking at
I have a 2011 23 vanguard mb mini and am looking for a 15ft boat or so, any one else run this motor on a boat and like your set up, just wanting to get some input,thanx.
Mon Oct 03, 2011 8:27 pm
Post Re: what boat should i be looking at
What are you wanting to do w/ your rig. What type areas will you be running.
WC CUSTOM 20X54 Battleship w/ Gator Glide Pushed & Pulled hard by an HDR!
Don't be scared...Hit It and Hold It!!!
Mon Oct 03, 2011 8:32 pm
Mostly just duck hunting maybe try to get into bow fishing. The area I mostly run is around 5 inches on a low day and is pretty soft but I do run bay front a lot which is really hard also. I was thinking about just going with open floor plan and deck infront on a 15ft flat bottom alweld, bad idea you think?
Mon Oct 03, 2011 8:36 pm
That's a easy question..
A Uncle J Custom Hull..
Built the way YOU want it.
www.unclejcustomboats.com
With Love,
Uncle J
Mon Oct 03, 2011 8:44 pm
Ideas not coupled with action
never become bigger than the
brain cells they occupied.
Owner
Mon Oct 03, 2011 8:47 pm
Are you running marsh and open areas? This will affect my answer. There are a lot of custom builders on here that can hook you up. I like my G-trax for what I do but alot of the coastal guys are running hard chined boats and really like them also.
Mon Oct 03, 2011 8:49 pm
Yea a lot of marsh areas
Mon Oct 03, 2011 8:53 pm
I was thinking like barnes. The rogue that G-trax makes would run good w/ that motor. If price is big factor you may check w/ some of the builders on this site and get just what you want and not spend much more than you would on the alweld and have a lot more boat.
Mon Oct 03, 2011 9:08 pm
Check this one out. Seems like it would be perfect for a 23hp. I have seen it and it is built like a tank. Looks like the price is right also.
viewtopic.php?f=62&t=22532
Tue Oct 04, 2011 2:16 pm
Uncle J built one for one of my hunting buddies and it really is a 1st class job!Really came out great!
Tue Oct 04, 2011 5:19 pm
16 foot, 48 at the widest, 36 at the narrowest. Square or tapered chine, with not a lot of extra boxes or weight.
I used to have a 23 way back in the day, it ran great on a 16x36 Godevil round chine boat. Would have done better on a tapered chine boat. In fact, a 16x42 would have been perfect.
24x60 Dual Prodrives
Tue Oct 04, 2011 6:04 pm
leatherwood, correct me if I'm wrong, but aren't you from here? Reason I ask is because several guys running 23's around here, best one I've seen so far has carb & exhaust & is running a 17/48 Weldbilt. Hauls azz for a 23 & carries a pretty decent load too. If you're local, I could set you up with a test ride.
1846 GTB & 35 GTR
Team Gator-Tail
(409) 720-8949
Wed Oct 05, 2011 9:26 pm
Thu Oct 06, 2011 9:19 am
Thu Oct 06, 2011 11:36 am
Team camo, yes I am from around here. Crosby texas to be exact. I just bought a used 1644 go devil slick bottom boat for my 23, haven't had a chance to run it yet, I know it won't win a race but I like the room and it should get the job done and if it doesn't I might upgrade to a man size motor next season. I paid 2800 for boat and trailer its a 2000 model boat. Was that a good deal? I will post how it runs maybe tomorrrow.
Sat Oct 08, 2011 6:16 pm
I think $2k was a fair deal, & with a lil work & $, that 23 will push you pretty good. If you decide you still want more, that hull will handle a 35, no sweat.
1846 GTB & 35 GTR
Team Gator-Tail
(409) 720-8949
Sat Oct 08, 2011 6:36 pm
What do you suggest I should throw on that motor to get a little more hop to my jump and how much. Thanx for any input
Sat Oct 08, 2011 7:31 pm
Try the usual bolt on parts (carb, heads & exhaust) & see how she does. I wouldn't go too much further than that with a Mini, tho.
1846 GTB & 35 GTR
Team Gator-Tail
(409) 720-8949
Sat Oct 08, 2011 8:01 pm
The boat build beg off. Lol
18x54 Cajun Performance with Stage 1 35 GTR W/ Mikuni
Sat Oct 08, 2011 8:31 pm
