It is currently Sat Dec 20, 2025 8:56 am
Reply to topic  [ 123 posts ]  Go to page Previous  1, 2, 3, 4  Next
 GDSD Props *oh & giga's a douche
Post Re: GDSD Props *oh & giga's a douche
Sat Oct 15, 2011 1:09 pm
Profile YIM
1854 Sportsman's Fab
2046 Uncle-J Skiff
35 GTR
Sat Oct 15, 2011 2:32 pm
Post GDSD Props *oh & giga's a douche
I'm real proud of you guys but I wasn't bragging on how many hours I have.
The only reason I brought up the hours on 4 different motors was to say I had never experienced a broken shaft after a prop had been torched off.
Sat Oct 15, 2011 5:49 pm
2046 Uncle-J Skiff
35 GTR
Sat Oct 15, 2011 6:29 pm
Something to think about. When you heat steel, it expands. When you get the prop cherry red, you are also heating the shaft too causing it to swell. Just put a little heat on the prop and it comes off fairly easy. Too much heat fuks you. Just try that next time. Still might take more than one try, but seriously, when you heat the prop that much, you heat the shaft too and you are back at square one. Just an FYI.
Sat Oct 15, 2011 6:52 pm
Mon Oct 17, 2011 10:51 am
Guess I've really never paid attention to the GD Prop threads, but I'm amazed at the amount of shit you have to do to get one off. What a shitty design.
Mon Oct 17, 2011 11:16 am
Well, in defense of the threaded prop design, you are suppose to leave 1/4 turn of play in the prop. And if you could remember each time you run it, you could use a rubber mallet to knock the prop loose of the rear washer, cause when you bump something the prop gets pinned against the washer/nut.
I'm going to try and make this a part of my "boat cleaning/maintanance" after each trip. 2 or 3 hits should knock it loose.
Mon Oct 17, 2011 11:33 am
Mon Oct 17, 2011 11:49 am
Mon Oct 17, 2011 12:41 pm
17x48 extreme stage 2 GTR
Mon Oct 17, 2011 12:57 pm
Mon Oct 17, 2011 1:20 pm
Lol dude if it's hour motors and your money paying for it it your broke shaft!! Dumb ass
Mon Oct 17, 2011 1:30 pm
Mon Oct 17, 2011 1:42 pm
BBb the whole point of this tread was how long and how many tools to change a gd prop!!
Mon Oct 17, 2011 1:45 pm
Jeez....been gone for awhile and you ladies are still up to the same gay $hit.
Mon Oct 17, 2011 1:47 pm
Mon Oct 17, 2011 1:53 pm
Mon Oct 17, 2011 2:02 pm
Mon Oct 17, 2011 2:14 pm
MMT Moderator
Damn y'all just knew I would be wrapped up with this tournament & benefit Thursday through the weekend... I just found this thread & not even about to start reading it lol...
GTB 1860 w/ 2019 GTR40XD-HO
Mon Oct 17, 2011 2:59 pm
all i read was the first page and that said enough for me LOL!! :lol:
Mon Oct 17, 2011 3:02 pm
Don't lie you know y'all both read the whole thing !! Lol
Mon Oct 17, 2011 3:04 pm
not i sir :shock:
Mon Oct 17, 2011 3:08 pm
Craig and DDM
Look closely at the 1st post and the (Original) Title of the thread....
GDSD Props
Anyone know how long or how many tools it takes to change one?
Why go on a lengthy search for longtail issues and bring them to a GDSD
thread
- that is a whole different animal.... Which led to my quote above about "is it more fun to LIE IN COLOR....
Cause it's deception...
Especially when LT props often last for years on end and even then
guys don't care so much about speed so they just keep using them....
SD guys are much more performance oriented an likely change props once
or more per season.... And yes I can get one changed with a 2x4 but
it don't take a rocket scientist to understand the value of buying the factory
removal tool - or borrowing one when ever you want to change a prop....
Eat - Sleep - Hunt ! ! !
Mon Oct 17, 2011 3:17 pm
Maybe im alone in this, but I use that neversieze stuff with silver in it and it never has been too hard at all. Usually comes right off with one swat of a rubber mallet.
Mon Oct 17, 2011 3:52 pm
Someone is crawfishing :lol:
Mon Oct 17, 2011 5:03 pm
Post Re: Re: GDSD Props *oh & giga's a douche
1850 & 36pd
Mon Oct 17, 2011 5:25 pm
Mon Oct 17, 2011 7:58 pm
Mon Oct 17, 2011 8:25 pm
You can place your reply wherever you want...
As you said earlier in this post..."read the title of this thread and the first post."
Good try though.
Mon Oct 17, 2011 8:29 pm
Did anything change from the LT to the SD as far as the way that the prop is installed?
Mon Oct 17, 2011 8:31 pm
FTR, I changed my shaft and seals because I bent the shaft. I never have any trouble getting the prop off by using nickel anti-sieze every 25 hours. I bought a new bushing and spare seals for when the factory bushing wears out.
1644 WeldCraft / 27 GDLT
Ranger R71 / 125 Merc
Mon Oct 17, 2011 9:02 pm
Mon Oct 17, 2011 10:44 pm
Except some folks medication.....
Can't tell if it's over medication or under medication ---- LOL
Can't wait for the smell of gunpowder at dawn ! ! !
Mon Oct 17, 2011 10:58 pm
My GDSD has has not had the prop off in maybe 3 or 4 years. I ran it in salt off and on and it has been in the barn. I know it is going to be a biatch after reading this thread.
It is at the weld shop right now getting a bunch of mods to the hull. I think I am going to start spreyin it with break penetrating oil for a good long while before I try to crack it open.
snakebreaker
Thu Nov 10, 2011 9:57 am
my dad and i took mine off for the first time ever since i got the motor three years ago, sprayed it with kroil the day before i took it off. The tools i needed were two large crecent wrenches, a pipe wrench, and two cheater bars. Prop came off in about 5 minutes.
35HP GATOR TAIL GTR W/ MARSHMELLOW EXHASUT AND MINKUNI CARB PUSHIN MY BIG AZZ AND A
16 X 50 ALUMAWELD HULL.
Thu Nov 10, 2011 10:25 am
I would imagine spraying it with break might get in there and aid in the taking off of the prop. I can't remember if I put no sieze on there or not. I sure hope I did. It could be one of those deals where I fully intended to do it, but never actually did it.
snakebreaker
Thu Nov 10, 2011 10:47 am
Glad I had this one bookmarked..
Wed Sep 05, 2012 3:13 pm
Priceless. He disappeared for a while after this thread.
Wed Sep 05, 2012 3:38 pm
:lol: :lol: that was a good read.
1850 Uncle J
Delta Performance level 4 GTR
Wed Sep 05, 2012 6:33 pm
