It is currently Tue Jul 15, 2025 9:34 pm
Reply to topic  [ 33 posts ]
 Upgrade suggestions for batter terminal connections:Video+
Post Upgrade suggestions for batter terminal connections:Video+
I burned the shiat out of my fingers this morning when I tried to tighten the wing nut on my battery terminal. My GTR23 with the decked heads and performance cam requires me to "pump" my starter to turn over the engine to start. This heats up my battery connections. I have one batter (a good one) to which my lights, starter and trim are connected. Do ya'll have recommendations to eliminate this issue...ie terminals and wires getting hot...larger cables, terminal adapters to accommodate multiple connections (right now they're just stacked on top of one another.). Thanks.
Wed Nov 16, 2011 12:59 pm
Post Re: Upgrade suggestions for batter terminal connections
Terminals shouldn't b getting too hot to touch, no matter how much compression your engine got. U have a connection that is loose. If the cable is crimped to the battery connector u should solder it. U need 2 check the wingnuts often too cause they will loosen up.
18'x54"CC Hanko/ 36PD
Wed Nov 16, 2011 2:00 pm
I tighten those mothers as tightly as can be with pliers and they still loosen. I think I'll switch to compression fittings. Here's a picture of my burned thumb.
Wed Nov 16, 2011 2:12 pm
Wed Nov 16, 2011 2:14 pm
I swear you are fucking retarded. Why didn't you fix this 6 months ago when you started having the problem? You are gonna wear that starter out if you don't fix it. You don't have anywhere near enough compression to put a strain on that starter. It's still a wiring or battery issue, just like it was when you started having problems.
Wed Nov 16, 2011 3:03 pm
Wed Nov 16, 2011 3:31 pm
Wed Nov 16, 2011 5:11 pm
Wed Nov 16, 2011 5:25 pm
Hey guidry,Take it to a welding shop and get them to weld that shit to your battery :lol:
Wed Nov 16, 2011 5:32 pm
At least the battery didn't explode in your face.
1644 WeldCraft / 27 GDLT
Ranger R71 / 125 Merc
Wed Nov 16, 2011 5:51 pm
Wed Nov 16, 2011 5:59 pm
Put some blue loctite on the wingnuts. That should keep them from backing off but you have an issue somewhere else if it is takig it that long to fire up.
CB come on man you didn't have to call the guy a tard :-)
Wed Nov 16, 2011 6:47 pm
Wed Nov 16, 2011 6:54 pm
Wed Nov 16, 2011 7:11 pm
Guidry knows that cb is just giving him a shit!Hunting season makes him mean!
Wed Nov 16, 2011 7:24 pm
Don't forget his profession. Don't blame him. Attorneys never admit guilt. :lol:
Wed Nov 16, 2011 7:30 pm
Wed Nov 16, 2011 7:38 pm
Cb you have a sick relationship with engines. You care more about how an electrical issue will affect my engine than you do about my burned finger. I think that describes how you relate to most people in your life. Just sayin.. I still like you.
Wed Nov 16, 2011 11:29 pm
Actually, I don't give a shit about your engine or your finger. Just saying we tried to help you with this problem a while back and warned you that bad things could happen. You chose to ignore the help and now you've burned yourself. You burned yourself because you are an idiot. :lol: Why would you think that any one of us care about you burning your finger, anyway? :lol:
Thu Nov 17, 2011 10:35 am
Thu Nov 17, 2011 12:14 pm
:lol: Maybe I do care. I think you should be locked in a padded room. That's probably more for other people's saftey than yours though. Guess I still don't give a shit about you. :lol:
Thu Nov 17, 2011 1:14 pm
Don't let them connections get too hot for cypress knee! wood + heat = Whoooofff
Thu Nov 17, 2011 1:18 pm
Thu Nov 17, 2011 1:28 pm
Post Re: Upgrade suggestions for batter terminal connections: UPD
Update photo of my burns
Thu Nov 17, 2011 1:39 pm
Thu Nov 17, 2011 1:41 pm
Fuggin water blisters.... Pop them suckas and put some neosporin on dat. DG got your tire fixed?
Thu Nov 17, 2011 1:52 pm
[youtube]http://www.youtube.com/watch?v=AzHfVSRc5sU[/youtube]
Thu Nov 17, 2011 2:06 pm
Thu Nov 17, 2011 2:32 pm
Post Re: Upgrade suggestions for batter terminal connections:Vide
:lol: I just noticed the video. You are definitely retarded. :lol:
Thu Nov 17, 2011 8:50 pm
Thu Nov 17, 2011 10:08 pm
MMT Moderator
Was he using burnt finger? :lol:
GTB 1860 w/ 2019 GTR40XD-HO
Thu Nov 17, 2011 10:32 pm
New terminal connections installed. Problem solved!!! Thanks CB.
Sun Nov 20, 2011 7:48 pm
Now I can sleep at night knowing that you are safe...
Sun Nov 20, 2011 8:07 pm
Users browsing this forum: No registered users and 109 guests
