It is currently Wed Dec 17, 2025 5:54 pm
Reply to topic  [ 22 posts ]
 Wedges
Post Wedges
OK, so I got the mods from Hoyt and discovered a bad porpoising problem. I got GT to weld me 2 wedges and a keel strip for the sliding. The keel strip works great, bites good in a slide. The wedges on the other hand stopped the porpoising, but robbed me of about 4-5 mph. I usually run in the center hole on the transom clamp, moved it to bottom and still can't get the mph. The top position would be too high I believe. Thinking about sacrificing the bounce for the speed. Please advise!!
ps - the porpoising only happens when I'm by myself (which is rare)
Ace
Cajun Performance 1854/GTR35 Tiller (Lil Daddy Mods)
Sun Jul 05, 2009 12:35 pm
Post Re: Wedges
If the wedges stopped the bouncing, then you would want to raise the motor to the next hole or trim it up. If that doesn't work take a little off the wedges with grinder. Moving it to the lower hole will just make it plow more. Good luck! BTW, how much speed did you pick up with the mods?
Sun Jul 05, 2009 1:04 pm
Post Re: Wedges
repositioning the weight( battery, gas tank, etc) in the boat could help. Those guys at GT know what they are doing you might want to check with them again and tell them your problem.
My Chessie is the Queen of the Marsh!!!!
"The democracy will cease to exist when you take away from those who were willing to work
and give to those who would not." Thomas Jefferson-1802
"When the Government fears the people that is liberty
When the people fear the government that is tyranny"- Thomas Jefferson
Sun Jul 05, 2009 1:09 pm
Post Re: Wedges
Wedges - are bad - pure drag - take them off....
Find a way to balance your boat - move the battery up front or some other weight re-distribution.... Maybe a bigger ice chest !
Eat - Sleep - Hunt ! ! !
Sun Jul 05, 2009 2:06 pm
Post Re: Wedges
Sun Jul 05, 2009 2:39 pm
Post Re: Wedges
Thanks for the replies guys. Then I have 2 more things to do. Move the pin to the highest hole and try it. If that don't work, then I'll be grindin the wedges off.
Ace
Sun Jul 05, 2009 2:58 pm
Post Re: Wedges
I 2nd what Stumpgrinder said. Take them wedges off and live with it.
Sun Jul 05, 2009 4:32 pm
Post Re: Wedges
My buddy has a boat with a bad porpoising problem and he found a big chunk of sheet lead that he would put on the bow for solo runs,he called it his friends.
Sun Jul 05, 2009 4:54 pm
Post Re: Wedges
Put it on the high pin. Only thing is when you get in some thick shit it needs to go back down. As for as then bounce ad a nother tank of gas to the front. or some other weight. if the wedges are slowing you down that much weight till you get in some shallow water or mud it will push the front even more down
17x48 extreme stage 2 GTR
Sun Jul 05, 2009 6:42 pm
Post Re: Wedges
get a grinder and start grinding on the wedges. take off enough material till the speed comes back and the bouncing stops. find the happy middle ground.
problem solved. :)
Sun Jul 05, 2009 7:58 pm
Post Re: Wedges
Ace
Sun Jul 05, 2009 8:04 pm
Post Re: Wedges
My 1660 Gatortail porpoised some by myself until I moved my trolling motor battery up front and got a 9 gallon tank up front instead of a 6. Haven't had any problems lately but I rarely run alone/unloaded. If you don't run alone a lot, I wouldn't be worried about it.
Sun Jul 05, 2009 9:45 pm
Post Re: Wedges
Thanks for all the posts guys. Made the decision to remove the wedges. :D :D
Ace
Mon Jul 06, 2009 10:37 am
Post Re: Wedges
Ace please tell us about your lil Daddy mods, what he did, and how much speed increase you got. :?:
Mon Jul 06, 2009 11:05 am
Post Re: Wedges
Ace
Mon Jul 06, 2009 11:20 am
Post Re: Wedges
24x60 Dual Prodrives
Tue Jul 07, 2009 9:15 am
Post Re: Wedges
So what is your point - other than rudeness - in his case the wedges were a bad solution to a simple problem of weight re-distribution.
Almost every post agreed that in his case he did not need or want them.
And nothing "will solve every problem you have or had" - except maybe selling the rig.
Tue Jul 07, 2009 10:18 am
Post Re: Wedges
Tue Jul 07, 2009 10:59 am
Post Re: Wedges
Gigafowl, you sometimes remind me of a wedge........ the simplest form of a TOOL. :lol:
Tue Jul 07, 2009 11:32 am
Post Re: Wedges
Giggafart
Tue Jul 07, 2009 11:48 am
Post Re: Wedges
Tue Jul 07, 2009 3:11 pm
Post Re: Wedges
even addin weight to the front isnt always a problem solver to gain speed back...may stop the nose from bouncin but also may not gain your speed back because you are forcing the nose down without lifting the rear of the boat out of the water more
like i said not ALWAYS a problem solver but should do the job
Pete Willett
WC Custom Boats - Tyler, TX
http://www.wccustomboats.com
Tue Jul 07, 2009 7:56 pm
