It is currently Tue May 28, 2024 8:17 pm
Reply to topic  [ 19 posts ]
 GATOR TAIL VIBRATION
Post GATOR TAIL VIBRATION
Any body has trouble with there motor vibration very bad threw the rpm range its not a constant vibration the boat is new with 4 hrs on it brought back to gatortail said nothing was wrong with it.. I road in plenty of gatortail that didn't have that much vibration. And for the smart ass people out there no shit they will have vibration.
Mon Feb 13, 2012 7:52 pm
In what range is the vibration!!
17x48 extreme stage 2 GTR
Mon Feb 13, 2012 7:56 pm
Post Re: GATOR TAIL VIBRATION
3850 rpm its not constantly it up and down I have a gdsd 35 and it don't vibrate nearly that much. Hoyt check the prop every this is good
Mon Feb 13, 2012 8:02 pm
Mon Feb 13, 2012 8:19 pm
Mon Feb 13, 2012 8:20 pm
Trim up some more....or maybe you are trimmed up too far and you just got a light tiller.
Black ops IITX marshstalker
1840 WC www.wccustomboats.com
fuel injected 25 GTR
Mon Feb 13, 2012 8:23 pm
Which hole are you in?
Mon Feb 13, 2012 8:24 pm
What kind of load did you have in the boat? And were you WOT?
Mon Feb 13, 2012 8:26 pm
Mon Feb 13, 2012 8:28 pm
The pin is the second one and prop half in the water. I was in it with no load I think i might take the motor off and but a rubber gasket on the outside of the transom the boat is noisy with vibration too
Mon Feb 13, 2012 8:31 pm
Does it do it all the time or just in gear? Did you pull the reverse cover to eliminate the clutch or rev ?
Mon Feb 13, 2012 8:34 pm
Just does in in the water no never took the cover off
Mon Feb 13, 2012 9:00 pm
Mine vibrates when cruising, just figured it was normal. It doesn't resonate through the hull though
2012 1860 GT Extreme 35GTR-STOLEN Thanks dik
2013 1860 GT Extreme 35GTR
Tue Feb 14, 2012 3:03 am
Tue Feb 14, 2012 7:31 am
Pop the cover off the clutch and see if anything looks like it is warped. A good visual of how everything operates will give you a better idea how to diagnose it.
Tue Feb 14, 2012 7:33 am
Thanks for all the help went ride in on of my buddies this morning his does the same thing he had a 1860 extreme i have a 17 54 no extreme i will take the cover off and check as well.
Tue Feb 14, 2012 8:17 am
In your first post I think you answered your question when you said yes I know they will be vibration!!
Tue Feb 14, 2012 9:05 am
Found the problem gator tail welded up the sides on the floor. And took all vibration out.
Fri Jul 06, 2012 7:45 pm
Fri Nov 02, 2018 12:41 am
Users browsing this forum: Majestic-12 [Bot] and 191 guests
