It is currently Sun Jul 13, 2025 8:05 pm
Reply to topic  [ 14 posts ]
 Idle problems
Post Idle problems
I have a 36pd which I have just added a mm exhaust I'm having a problem with the idle when the clutch is engaged (this is not in the water ) it will die unless I stay on the throttle but I think my probelm might be the new fuel pump I added I think it's either my putting enough fuel or it's over flowing the carb its rated 1 to 3.5 psi any suggestions on what to do
1748 SDB being pushed by a 36pd
Thu Feb 23, 2012 7:36 pm
Post Re: Idle problems
Rpms around 1200?
Thu Feb 23, 2012 7:47 pm
Thu Feb 23, 2012 7:54 pm
why they aftermarket fuel pump?
Thu Feb 23, 2012 8:05 pm
hows it run at wot.? might have got crude in the fuel curcuit when u changed pump. if u have a primer bulb gently pump it and see what happens. when it starts to die. reset your idle mixture also. what kind of carb. ?
Thu Feb 23, 2012 8:06 pm
DDM- it had one on it when I bought It after awhile the wires corroded on the last one so I got another one
Richard - its stock carb
Thu Feb 23, 2012 8:14 pm
hows it run with wide open throttle. under load.?
Thu Feb 23, 2012 8:19 pm
Haven't had then chance to take it out just put the exhaust on tonight
Thu Feb 23, 2012 8:23 pm
valve lash good?
Thu Feb 23, 2012 8:44 pm
Sorry but what is valve lash ?
Thu Feb 23, 2012 8:48 pm
http://www.youtube.com/watch?v=hGkn0jR9RJM
Thu Feb 23, 2012 9:13 pm
What should the rpms be when idling
Sat Feb 25, 2012 6:23 pm
Sun Feb 26, 2012 3:49 am
Ok do when I do have it idling at 1100 it stays at a 1100 for a sec then slowly idles down I think the pump is flooding the carb the pump is rated at 1 to 3.5 psi wht should the rpms be when the clutch isn't ingaged
Sun Feb 26, 2012 12:13 pm
Users browsing this forum: Google [Bot] and 105 guests
