It is currently Tue Dec 23, 2025 5:49 pm
[ 7 posts ] |
Quack Attacker89
Joined: Fri Feb 04, 2011 3:25 pm Posts: 92 Location: Alvin, TX
 3/4" or 7/8" shaft?
I'm getting to the time on my 16hp SD build to order my shaft and bearings. Was wonder which would be better for this motor or if it would really even matter. I'm leaning towards the 7/8" right now but I know the old LT ran a 3/4" shaft and didn't know if there was a reason for it.
_________________ 14' aluminum can powered by a 16hp GDLT
| Thu Feb 23, 2012 7:12 pm |
countryhick
 Re: 3/4" or 7/8" shaft?
You can get aftermarket props for a 3/4 shaft much easier and cheaper.
| Thu Feb 23, 2012 8:13 pm |
Woodiebuster
Check and see what size shaft the prop you will run is first.
Make sure it is a true surface piercing prop.
| Thu Feb 23, 2012 9:59 pm |
Quack Attacker89
I was planning on running a 11X10. Hill marine has em both ways I guess its a surface piercing prop it looks different than my LT prop.
| Thu Feb 23, 2012 10:37 pm |
sftull
Joined: Tue Mar 08, 2011 1:33 pm Posts: 601 Location: Rock Hill, SC
go with 3/4. alot easier to find bearings, seals and props.
_________________ 1846 GTB and 35 GTR
New GT Rig
Old Surface Drive Build
| Mon Feb 27, 2012 3:28 pm |
Robn1020
Joined: Mon Feb 16, 2009 6:09 pm Posts: 4232 Location: Cypress, TX
Whoever took your avatar picture got a camera lens full of pintail on the collision.
| Mon Feb 27, 2012 3:37 pm |
Buzz Killington
3/4 all the way cheaper for parts, lighter, more universal seals etc...(in case of breakdown)
B. MacDonald
| Tue Mar 06, 2012 6:17 pm |
[ 7 posts ] |
