It is currently Thu Dec 25, 2025 1:36 am
[ 7 posts ] |
Quackkillz
Joined: Sun Dec 04, 2011 4:57 am Posts: 535 Location: Bottom of da boot
 Thompson trim unit ?
Can anybody tell me what is the average life span of a Thompson trim unit? I bought my mb sd used in February and I was told the trim would probably go out soon and it did so I changed it saturday. I never thought of asking how often he had to change it. I'm just trying to get an idea if any of y'all can help, thanks.
_________________ 1648 weld bilt being followed by a 35 gtr
| Tue May 01, 2012 6:51 am |
GSUrugger
 Re: Thompson trim unit ?
_________________ Gator Trax 1644 HD pushed by a screamin' MB Mini 35
| Tue May 01, 2012 7:09 am |
SCmudder7071
Usually over 100 hours. The seal that the shaft slides through is the culprit on the Thompsons. Keep some grease rubbed on the shaft/seal and youll squeeze a few more hours
_________________ 1754 Extreme/LAProp Stage 2 GTR
| Tue May 01, 2012 8:38 am |
Quackkillz
Good to know on the grease, my motor had 105 hrs when I changed it so it's probably the first time, I'm guessing, thanks a lot.
| Tue May 01, 2012 4:16 pm |
med
Joined: Wed Jan 14, 2009 8:25 am Posts: 6432 Location: the dark side of the moon
Quack look around on the mb Site and there's a guy that told how he repaired his. It might save you some cash next time around.
_________________ 1850 & 36pd
| Tue May 01, 2012 5:07 pm |
Quackkillz
Thanks med, I'll check it out, I know when I took my old one off the seal was dry rotted pretty bad, if I can make it last longer or fix it that would be nice.
| Wed May 02, 2012 2:43 am |
Smoke
Joined: Fri Jan 23, 2009 1:27 pm Posts: 1095 Location: SW Michigan
The trick to keeping them going is to check the seal often. If it looks damaged or degraded pull the unit off and repalce the seal. Their only $8.00-$10.00 and a piece of cake to change. If the seal gets damaged the unit will get wet and take a shit. I am thinking I will change mine out once a year. Cheap insurance to make them last.
_________________ 1854 Prodigy Open HDR/Stage 3 mods Prodigy Boats Pro Staff BPS Swamp Staff Member Blackwater Marine LLC.
| Thu May 10, 2012 6:14 pm |
[ 7 posts ] |
