It is currently Mon May 12, 2025 7:52 pm
Reply to topic  [ 9 posts ]
 Romving the shaft on a GTR
Post Romving the shaft on a GTR
I am planning on taking the shaft off my gtr i think the pulley has moved because my belt is out of alinement. I was wondering if anyone had some pointers or pictures? thanks
Thu Aug 16, 2012 8:56 am
Post Re: Romving the shaft on a GTR
How far out of alignment are you talking? Pulling the shaft is as easy as removing the bolts and the brace bolt. It should come out after some finessing. Grab your prop and try to push the shaft in and out (like sliding it in and out the shaft tube). If you have movement your Wear sleeves may have gained slop and allowed the shaft to "slid in or out and cause some mis alignment. I can walk you through the fix.
Thu Aug 16, 2012 9:03 am
Thu Aug 16, 2012 9:19 am
When you install those parts check the alignment again. If it is still out of whack, then you should replace the wear sleeve behind the pulley in between the big roller bearing in the upper bearing housing.. That requires removing the LU off the housing. I did it all my first time in about 3 hours. Now with knowing how it goes together it is a breeze.
Thu Aug 16, 2012 9:47 am
Thu Aug 16, 2012 10:00 am
Yeah i got mine from calen. It was a a little over $100 for everything in the lower unit. Just holler here if you need help.
Thu Aug 16, 2012 12:06 pm
so today i removed the lower unit reviling that the key was sheared and pulled the treads out of the nut that olhd the pulley on the shaft anyone know wat kind of key stock i will need to get
Wed Aug 22, 2012 10:10 pm
1/4" make sure the new key fits tight in the shaft. you may have to replace the shaft and taper lock if the key way grooves are not tight
Calen's Engine Service
337-578-4434
Thu Aug 23, 2012 5:24 am
Ok thanks Calen I'm bringing it to work with me I'll try finish getting it apart didn't have the snap ring pliers at home
Thu Aug 23, 2012 5:44 am
Users browsing this forum: Google [Bot] and 131 guests
