It is currently Tue Apr 07, 2026 10:04 am
Reply to topic  [ 22 posts ]
 what a saturday...
Post what a saturday...
took ma 36 pd out fa a ride down bayou pinchant to da duck lease when it happend.. hit a lil bit of lillies n went to clear ma wheel out when i noticed dat da two bushings in da back split in half.. had to take da bolt out of ma stops fa da trim and wedge a cork underneeth it to make da 45 min. ride back to da launch.. bushungs seems to be a very bad design n wonderin if n e of yall boys had this problem before n what yall did...
Sun Aug 09, 2009 3:41 pm
Post Re: what a saturday...
Where did you attend grade school?
Sun Aug 09, 2009 3:58 pm
Sun Aug 09, 2009 4:00 pm
da one ya grandma used ta drop me off at
Sun Aug 09, 2009 4:01 pm
Sun Aug 09, 2009 4:11 pm
I dont have any clue what your talkin about.... Try using some descriptive words and some periods and commas.
Sun Aug 09, 2009 4:26 pm
dey got four rubber bushings wit studs under ya tiller handle two of em broke on me i wanna know if dey offer n e different design for em cause da ones it comes wit sucks....
Sun Aug 09, 2009 4:37 pm
Ok...
So which ones did you break???
The front or back ones???
Sun Aug 09, 2009 4:46 pm
both back ones... shoulda seen me tryin ta drive back to da camp wit da tiller handle floppn like a limp noodle ;)
Sun Aug 09, 2009 4:48 pm
Well tell me this... Is there a 3/8" bolt back there next to those rubber things?
Sun Aug 09, 2009 4:57 pm
jus the ones comming out of both sides
Sun Aug 09, 2009 5:33 pm
If theres not a 3/8 bolt going throught the tiller base plate and the engine mounting plate right in front of the right back rubber mount (Between the block and the tiller) then there lies the problem! Call PD in the am, they'll get you back going.
Sun Aug 09, 2009 5:51 pm
i seen a hole with nothing in it.. what does that bolt do???? :evil:
Sun Aug 09, 2009 5:53 pm
It takes the load off the mounts when exerting a downward force. ( simply put it keeps the mounts from breaking).
Sun Aug 09, 2009 5:56 pm
preciate it.... looks like a bolt was never even put in. theres no scratches on da paint around da hole like it would've vibrated n backed out..
Sun Aug 09, 2009 6:35 pm
Had similar issue. Only the bolt was not tightened on mine still broke the rubber bolts deals. Can't wait for that to happen in November in the cold while hunting or on a trip somewhere out of state.
2060 Phowler Extreme
Tandem Axle All Aluminum Trailer
Pro Drive 36 Stock + EVT loud exhaust
Sun Aug 09, 2009 6:44 pm
could you replace the rubber mounts with a teflon bushing and a 3/8 stud all the way through instead
Sun Aug 09, 2009 7:18 pm
Sun Aug 09, 2009 7:30 pm
aight preciate it Mitschke
Sun Aug 09, 2009 7:34 pm
No problem...
Like preston said...
That bolt will limit the travel of that rubber isolator. So when you push down on your tiller handle, and you lift your motor up, the bolt takes all of the weight so the isolaters dont.
Sun Aug 09, 2009 7:39 pm
and when you put the bolt in there you don't have to dog tighten it down, just tighten it up until it touches on both sides then give it a half a turn or so until its snug.
( use a lock nut! ) lol
Sun Aug 09, 2009 7:41 pm
roger dat!!!!!!!! not asshole tight n teflon nuts.....
Sun Aug 09, 2009 7:43 pm
