It is currently Sun Jul 13, 2025 5:24 am
Reply to topic  [ 14 posts ]
 Short transom gatortail
Post Short transom gatortail
Could someone post a picture of a gatortail trimmed all the way down, so i can compare
1650 ribbed abused by a Gt-35 and push pole reverse
Sat Nov 24, 2012 8:30 pm
Post Re: Short transom gatortail
What ya need to know. If your not trimming deep enough, make sure you are on bottom pin
Sat Nov 24, 2012 8:50 pm
You got it, its on bottom pin, belt housing is about two inches from bottom but i can do shit in shallow water. Big blade prop 12" measured. I feel like im not getting to dig down deep enough bc i spray muddy water everywhere!
Sat Nov 24, 2012 9:07 pm
You post a photo of your motor. A couple different angles
Sun Nov 25, 2012 5:45 am
Whats your transom angle?
Sun Nov 25, 2012 8:05 am
I'm at work but can when I get home. But short/tall transom should be the same at the bottom of the boat.
23gtr crossover Mikuni
Sun Nov 25, 2012 8:30 am
Beings his signature says Ribbed Boat, I can pretty much guarantee that it is a 16 degree transom. Not enough angle.
You need to shim outside top out about 1/4" or so. Then ya problem will be resolved.
Sun Nov 25, 2012 9:41 am
When I had my ribbed boat I ran my GTR with the pin in the bottom hole. I was able to trim up to just the right height for the prop to be 1/2 out and down enough to dig out in the shallows.
I hope this helps.
Sun Nov 25, 2012 11:15 am
It doesn't help
Sun Nov 25, 2012 12:20 pm
Sun Nov 25, 2012 12:51 pm
Sun Nov 25, 2012 12:55 pm
^^ that just a 1x4?
Sun Nov 25, 2012 1:16 pm
1/4" x 2"
Sun Nov 25, 2012 1:45 pm
Its an 1650 xpress. When i bought it, it already had shims but they are in the inside ...... gonna change that and see. Also it stays on the bottom hole. Thanks for the replies!
Sun Nov 25, 2012 7:30 pm
Users browsing this forum: Google [Bot] and 85 guests
