It is currently Thu Dec 25, 2025 2:31 pm
Reply to topic  [ 37 posts ]
 Sand
Post Sand
Is there ne thing that you can do to a prop to make it last longer in sand cause I'm going throuh a prop every 40-50 hours and they ain't cheap
2010 gtr cdi with a stage 2 pushing a 18x46 home made HEAVY DUTY boat
Wed Jan 09, 2013 11:39 am
Post Re: Sand
Sand is the devil
Wed Jan 09, 2013 11:41 am
MMT Moderator
Post Re: Sand
Yeah, dont run in 10" or less... Pole through it.
GTB 1860 w/ 2019 GTR40XD-HO
Wed Jan 09, 2013 11:43 am
Post Re: Sand
My entire lease is sand and the deepest it gets is about a foot. I'm not about to push pole 1 mile to the camp then another 1/2 mile to the blind
Wed Jan 09, 2013 11:48 am
Post Re: Sand
Get an airboat
35 GTR - 1754 Extreme
MMT Moderator
Post Re: Sand
Wed Jan 09, 2013 11:50 am
Post Re: Sand
3 of the guys on our lease have air boats. Lil expensive I was thinking more along the lines of trying to get one hardened
Wed Jan 09, 2013 11:55 am
Post Re: Sand
Long tail
Wed Jan 09, 2013 12:05 pm
Post Re: Sand
a foot or less with sand bottom? take the four wheeler...
Wed Jan 09, 2013 1:09 pm
Post Re: Sand
pd36 fpr 1754 cc rig
Wed Jan 09, 2013 3:36 pm
Post Re: Sand
An Argo
Quote:
Wed Jan 09, 2013 4:03 pm
Post Re: Sand
^^^ with an outboard
Wed Jan 09, 2013 4:16 pm
Post Re: Sand
Wed Jan 09, 2013 5:45 pm
Post Re: Sand
Ok I should have named topic can u get a prop hardened cause that is what I want to know I know they sell a sand rock guard for gator tail but don't know of any one that runs one
Wed Jan 09, 2013 6:02 pm
Post Re: Sand
Wed Jan 09, 2013 6:05 pm
Post Re: Sand
Try ceramic coating... that stuff is harder than a whores dream^
Wed Jan 09, 2013 6:08 pm
Post Re: Sand
20 hours and I'm through a prop but I ain't stopin I asked this question some people said mud buddy prop is higher Rockefeller or some shit that means its harder metal and it also has a bigger leading edge but they also said I'd loose speed with it so basically what I got was either accept the fact that sand will wear your prop or buy an airboat. I had a long tail and ran it in the same condition and my prop didn't last any longer but I tend to not give a f@&$ so maybe if you baby it it would work
Wed Jan 09, 2013 7:19 pm
Post Re: Sand
Wed Jan 09, 2013 7:25 pm
Post Re: Sand
Sat Jan 12, 2013 8:47 am
Post Re: Sand
Just thinking about this from refinery experience with various alloys, you obviously have to find the right mixture of hardness vs ductility. In general, the harder the metal, the more brittle it becomes. You may get something very erosion resistant in sand but the first solid submerged object your prop hits, you break a blade.
Ceramic coating would offer some resistance. But, it would also be brittle and easily chipped or broken off.
Maybe a weld overlay hard facing using something like a Stellite 12 would probably work when you go to have old prop reworked.
Have one built out of titanium or tungsten or Hastalloy. Probably not very affective. You would have to do it at least once to compare life between the stainless and other alloy. But these are brittle alloys, also.
There are several companies out there that offer thermal spray coatings for corrosion/erosion resistance. If you know somebody in that field, it could be a cheap experiment to see how long that stuff holds up.
My curiosity is piqued with this because I run some very sandy and sandy loam type areas and am sure I have a lot of wear going on.
This is my first year with my MM. After hunting season, I will give something a try and let everybody know the results.
Sent using Morse Code from my not so smart phone.
Sat Jan 12, 2013 9:56 am
Post Re: Sand
We use a carbide coating on our carbon chutes at work. That stuff is hard as woodpecker lips. Pretty expensive though.
Sat Jan 12, 2013 10:07 am
Post Re: Sand
All we have is sand. Ya burn a prop in 30 -40 hrs. Its just the way it is.
Sat Jan 12, 2013 12:01 pm
Post Re: Sand
I know it's unlikely to last, but...Ceracote or one of the other gun coats would be a relatively inexpensive experiment. Yea, I know.
Mount a reversin' plate under the skeg :lol:
Sat Jan 12, 2013 1:08 pm
Post Re: Sand
Ok now I'm thinking too. Does anybody do them in steel, now hear me out, I worked for a company we built farm equipment and farm equipment runs in abrasive environment all day long.
Our plough mole boards were pressed from wearalloy.
Hard facing is an interesting idea too, but if an digger can work a beach not wear a bucket off I think we could expect better from props.
Sat Jan 12, 2013 2:38 pm
Post Re: Sand
Sat Jan 12, 2013 7:02 pm
Post Re: Sand
Sat Jan 12, 2013 7:18 pm
Post Re: Sand
The problem with props is that u don't have much there to begin with. Once they wear just a little they're shot. Farm equipment on the other hand is beefed up to the max. It takes a considerable amount of wear before it starts to effect performance.
Sat Jan 12, 2013 7:27 pm
Post Re: Sand
We got stainless props that get fucked up in sand, deal with it
Sat Jan 12, 2013 10:22 pm
Post Re: Sand
Sun Jan 13, 2013 12:11 am
Post Re: Sand
Sun Jan 13, 2013 12:24 am
Post Re: Sand
diamond coated/impregnated blade if that dont get it nothin will!
Gator Trax Hybrid 1654 HuntDeck
Sun Jan 13, 2013 12:49 am
Post Re: Sand
A prop with bling. I want one!
Sun Jan 13, 2013 5:26 am
Post Re: Sand
Get a hovercraft you lazy azz!
Sun Jan 13, 2013 5:41 am
Post Re: Sand
Here in Michigan just about everywhere you run is either sand or sand mixed mud or rocks. So push pole everywhere and forget the mm? Yea ok I wear a prop out a couple times a year. I've tried to reweld them but never seem to perform like the stock prop. I have access to a ceramic coater I use for some of my machine details at work. I may give the ole boy a call and ship it out with my next batch of details to get coated. It can't hurt to try. Whats the worse that could happen......it wears out again.
I have a brand new bb here i'm going to send out for ceramic coating.
Smoke
1854 Prodigy Open
HDR/Stage 3 mods
Prodigy Boats Pro Staff
BPS Swamp Staff Member
Blackwater Marine LLC.
Sun Jan 13, 2013 11:32 am
Post Re: Sand
Gotta pay to play!
Mon Jan 14, 2013 7:28 pm
Post Re: Sand
About 10 years back, I did some prop testing with one of the mud motor manufacturers where we had 3-4 blades cryogenically tempered. The testing did show an increase in life, but untill you get to the point where you can fill a cryo chamber with props, it is not very cost effective per prop. At that time the manufacturer was using a 17-4 SS material in their prop and decided that it was much more cost effective to precipation harden it to an H900 or H1150 which can be done in an inexpensive heat treat oven.
Tue Jan 15, 2013 12:23 pm
Post Re: Sand
Stay away from it. Honestly , or buy new props often .
Semper Fi
16x38 WC Skiff 35 MB HD
Thu Jan 24, 2013 8:54 pm
