It is currently Tue Dec 23, 2025 6:22 pm
[ 20 posts ] |
Rattling sound near prop, PD 36 with 22h
Docott
I was out in the marsh the other day, in shallow water, about 6-8", when I noticed a rattling sound coming from the prop are. Sounded like it was hitting rocks or oyster shells. I trimmed it out of the water. Everything looked normal, but the sound continued. It stops when I put it in neutral. On the trailer, it gets better, but doesn't go away completely at higher rims in gear. I talked to Peck at PD. He said it sounded like the normal slack in the gears, and perhaps I was just noticing now. I'm not at all saying he's wrong, and I think it's probably normal, but I'm pretty sure it wasn't doing it before now, so I thought I'd ask. I haven't any close hard use, or hit anything.
Thoughts?
Thanks.
Spence
_________________ Phil Robertson said,"It seems like, to me, a vagina -- as a man -- would be more desirable than a man's anus,"
| Thu Jan 24, 2013 6:51 pm |
CJB
Joined: Tue Sep 13, 2011 11:46 am Posts: 5216 Location: Across the Bayou, LA
 Re: Rattling sound near prop, PD 36 with 22h
Bearing above gear case may be going bad. That happened to me, all of a sudden one day the LU got noisy and it was the bearing. Had it changed and everything went quiet...
_________________ 35 GTR - 1754 Extreme
| Thu Jan 24, 2013 6:55 pm |
Kmoppert
Joined: Tue Jun 05, 2012 3:48 pm Posts: 2006 Location: Baton Rouge, LA
Could your cav plate be loose?
_________________ "There's nothing a duck hunter hates more than another duck hunter" ----------------------------------------------------------------------------------------------------------------------------------------------- Custom 17x48 with a new Gen III Prodrive.
| Thu Jan 24, 2013 6:56 pm |
Docott
Cav plate-I don't think so, but I'll double check. I ain't stupid  but what/where do you mean " bearing above the gear case"?
| Thu Jan 24, 2013 7:14 pm |
take'emgator
Joined: Mon Oct 19, 2009 6:38 pm Posts: 10201 Location: SETX
is prop loose
| Thu Jan 24, 2013 7:15 pm |
Docott
Gear cas-Wouldn't that be unusual on a motor with only 22h? Not doubting, just asking.
Prop is tight.
| Thu Jan 24, 2013 7:16 pm |
CJB
I say gear case/gears/whatever you want to call it, but there is a bearing just above the gears. Does it only make the noise when clutch is engaged? The bad bearing may not be the case for you, but the way you're describing it sounds similar to what was wrong with mine..
| Thu Jan 24, 2013 7:21 pm |
CJB
I think will had to have his changed also...I think of you leave the reverse tension knob tight it'll wear on that bearing, could be wrong but I know you shouldn't leave the reverse knob too tight
| Thu Jan 24, 2013 7:23 pm |
Kmoppert
| Thu Jan 24, 2013 8:18 pm |
bayouboy
Joined: Tue Jan 13, 2009 6:08 pm Posts: 5376 Location: Venice, La
its more than likely the gear lash, check your oil level. also the upper bearing needed to be greased every 50 hours or so. its a zerk fitting located on the port side the motors behind a 1/2 inch plug on the mid section. 2-3 pumps will do it.
the tension knob if left tight will prematurely wear the lower Teflon sleeve.
| Thu Jan 24, 2013 8:36 pm |
Docott
Thanks bb. Now I may be stupid, but... What toes that tension knob do anyway?
| Thu Jan 24, 2013 9:53 pm |
bayouboy
some times when going into reverse in the deeper water the lower unit will keep moving with the power head so the tension knob is there to hold tension on the lower unit so that the manual reverse will ratchet around. its not normally an issue in the shallows do to the mud holding the skeg. once your back in forward you should back off the tension on it. if you keep it greased well you really don't need it imo. I haven't used mine in years.
| Thu Jan 24, 2013 10:13 pm |
Docott
We're talking about that 2-3" knob on the lower unit right? I have auto reverse. Any "experts" on/near the Northshore who could take a listen to it this weekend? Or is there anywhere I could take it nearby? As far as I know, the nearest place is in Houma for service on anything other than the mote itself. Also, I greased everything with zerk fittings the other day, but on some of them, I could tell if any was going in bc none was coming out anywhere on the lower unit, etc. I know greasing the prop area/fitting worked bc some came out by the prop nut. Same thing with the joint between the foot (part that turns around) and the rest of the lower unit (stationary part) .
Wish I had someone to walk me through the routine maintenance. I'm actually pretty handy, but on this, I obviously don't have the knowledge.
Thanks.
Spence
| Thu Jan 24, 2013 10:43 pm |
Docott
Frog
| Fri Jan 25, 2013 4:18 pm |
T-Bubba
Joined: Wed Feb 18, 2009 6:43 pm Posts: 3958 Location: Centerville, La
mine rattles and makes noise... some do it some done... i would change the breakin gear oil and grease the top bearing good
_________________ I gave up mud motors
| Fri Jan 25, 2013 4:24 pm |
jayhawkmarauder
check your heat shield on the exhaust?
| Fri Jan 25, 2013 5:44 pm |
Docott
How do I change the gear oil? I've greased the other part. Heat shield is tight.
| Fri Jan 25, 2013 6:14 pm |
med
Joined: Wed Jan 14, 2009 8:25 am Posts: 6432 Location: the dark side of the moon
Goto the prodrive site and download the maintenance .pdf. It'll tell you what to do.
_________________ 1850 & 36pd
| Fri Jan 25, 2013 10:28 pm |
Docott
Thanks
| Fri Jan 25, 2013 11:07 pm |
bookum1
I am experiencing the same thing on this motor. It has 16 hours on it. I bought it about a month ago new. Taking it to the dealer on Monday. Is it the concesus that this is norman?
| Sat Jan 18, 2014 5:47 pm |
[ 20 posts ] |
