It is currently Wed Mar 18, 2026 4:14 pm
Reply to topic  [ 13 posts ]
 70hp Ducati Surface Drive Prop?
Post 70hp Ducati Surface Drive Prop?
Hello,
I have a spare 750cc Ducati motor that I would like to purpose for a home built surface drive mud motor. It produces 70hp and spins at 9000rpm tops. Although, it stops building power at about 8k. I have no doubt that I will manage the build just fine. The question that I do not have the answer to is: What prop should I use? Is a prop made for this hp figure? Also, what rpm should I gear the prop to spin at for optimum performance?
Thanks!
Mon Mar 04, 2013 10:02 pm
Post Re: 70hp Ducati Surface Drive Prop?
Depends what kind of torque you'll be making for gearing
Mon Mar 04, 2013 10:11 pm
So it will have a transmission?
1850 Uncle J
Delta Performance level 4 GTR
Mon Mar 04, 2013 10:17 pm
I will tell you from experience that you need lots of torque when testing a new motor. I had a 650 rotax and cvt tranny( out of can am outlander) and tried every trick in the clutching book including a $900 primary clutch and still couldn't get the low end torque to the prop. That same engine would pull the front end of the ground in the four wheeler on 31 outlaws but couldn't make the torque for a mud motor application, believe me I know :lol:
8 foot sneak boat with 8hp go devil going Mach 1
Layout blinds and a whole bunch of decoys
Mon Mar 04, 2013 10:18 pm
Yes. It has a 5spd transmission that is integral to the motor, as it is a motorcycle engine. I imagine I will simply put it in an appropriate gear and leave it there. The motor makes 45ftlb of torque.
Mon Mar 04, 2013 10:22 pm
1850 Uncle J
Mon Mar 04, 2013 11:30 pm
i beleive the prop is designed to not spin over 2k rpms, your gonna have to gear it way down and hope you get it right. But you are wasting your time, all i can say :)
Mon Mar 04, 2013 11:54 pm
The first solid thing you hit you can kiss that gear good-by. But on the brite side you have 4 more to get you back to the drawing board!
Tue Mar 05, 2013 12:01 am
I see you throwing a lot of money at this thing trying to get prop and gearing right. Tourqe is whats gonna get that prop spinning and you dont have a ton. If you run a huge prop your gonna have to gear way down which will make you lose the top end.
1648/Generac powered SD, 42mm mikuni,flat tops,cam.
Thu Mar 07, 2013 10:04 pm
What kind of clutching system would you use? it seems like you would smoke a regular clutch.
-Greg C.
Sat Jun 22, 2013 6:45 am
sounds like you need a centrifugal clutch
Sat Jun 22, 2013 7:17 pm
just sounds plain crazy, lol
19x48 MAD MAN CUSTOMS 36PD (stock for now)
Sun Jun 23, 2013 3:51 am
Just me thinking out loud, but the CVT would work if it was setup to operate manually/lever. Pick what ever ratio you want depending on hole shot, top end, or rooten. It would also take the strain off the block and allow/maintain the higher rpms and run a variety of pitched props.
Sun Jun 23, 2013 8:31 pm
