It is currently Sat Mar 28, 2026 4:27 am
Reply to topic  [ 7 posts ]
 GTR dying when trimmed up ??
Post GTR dying when trimmed up ??
Just installed a fuel/water separator. Ran perfectly before install. Now motor dies when trimed up to get rooster tail. Is my fuel pump not strong enough to pull through filter? I can run half throttle trimmed down and everything is fine. Trim up and open her up, she dies..
1854 InstaGator
35 GTR w/ carb and MM exhaust
"Addicted is an understatement"
*GEAUX TIGERS*
Fri Mar 22, 2013 11:59 pm
Post Re: GTR dying when trimmed up ??
Did you check everything like we talked about? Find anything?
1846 GTB & 35 GTR
Team Gator-Tail
(409) 720-8949
Sun Mar 24, 2013 1:01 am
ive got the large fuel water seperator on a gator tail my tank is all the way in the front of my boat, got the larger carb, heads and cam with no probs. should not be that. must be sucking air somewhere.
1754 southfork with hopkins prop on moded gtr
Sun Mar 24, 2013 9:50 am
I bypassed my separator and had zero problems. I have 24' of 5/16" fuel line. What was weird was that it would only die when I trimmed it up. If I ran it sub surface, it didn't die
1854 InstaGator
*GEAUX TIGERS*
Sun Mar 24, 2013 12:18 pm
Leaking fitting or plug on the F/W separator. Will's was giving us a fit trying to tune his motor, replaced it (because fittings were stripping off) & unhooked his e-pump, now he's got zero problems. Make sure everything is good & tight so it's sealing off.
1846 GTB & 35 GTR
Team Gator-Tail
(409) 720-8949
Sun Mar 24, 2013 12:25 pm
1854 InstaGator
*GEAUX TIGERS*
Sun Mar 24, 2013 12:33 pm
Sun Mar 24, 2013 4:39 pm
