It is currently Wed Jul 02, 2025 12:19 pm
Reply to topic  [ 51 posts ]  Go to page 1, 2  Next
 Vmax SHO...
Post Vmax SHO...
Any of you play with props on these engines,,,any good props that work better than stock?
Sun Mar 17, 2013 8:40 am
Post Re: Vmax SHO...
What kind of boat is it on?
Sun Mar 17, 2013 8:53 am
Sun Mar 17, 2013 9:03 am
What are your rpm's trimmed out? You should be able to turn atleast a 24 probably more.
There is about 1 million props you could put on it so I got a few questions
What are you looking for?
Top end?
Hole shot?
Best of both?
Carry a load better?
I'd look into the turbo props, or a mercury bravo1
Sun Mar 17, 2013 9:15 am
I'd try either the 23p yamaha pro xl or a 23p tempest plus. Also from what I've read Bill Kenner has done extensive prop testing with different motors and it probably wouldn't hurt to contact Blackjack directly to see what they reccommend.
To fish or not to fish? What a stupid question.
17/54 Extreme Hull with a 35GTR with just a basic build.
Sun Mar 17, 2013 9:18 am
Sun Mar 17, 2013 9:33 am
6700 rpms thats crazy:o
Sent from my SAMSUNG-SGH-I547 using Tapatalk 2
Sun Mar 17, 2013 9:37 am
Sun Mar 17, 2013 9:39 am
I dont run it that hard all the time to...just every now and then play with some bass boats with it. Other then that, its cruising at 4000rpms....
Sun Mar 17, 2013 9:42 am
Mercury props are some of the best. The reason I said to try the bravo is because all the fast bay boats around here use it. I would call Eric at scb or call the guys at full throttle boat works, they are the one of the biggest if not the biggest dealer of mercury racing and know alot about props and they use alot of sho's. they test props every day and have probably tested props on a boat set up just like yours! Trust me on this they make 90mph bay boats
Sun Mar 17, 2013 9:45 am
Look up the people I told you about. They will let you try props before you buy them. And I'm almost 100% positive I've seen them do a review on a black jack.
Sun Mar 17, 2013 9:47 am
Will do thanks...
Sun Mar 17, 2013 9:55 am
my bravo1 and bravo 1xs are the best props ive ever used for holding a bite..cant recall the name but full throttle and scb are handling them..a new line of mercury racing props..promax prop i believe it is..prolly sale my bravo 1 to give one of these a try
Sun Mar 17, 2013 12:00 pm
Sun Mar 17, 2013 12:05 pm
Start with a 21 and go up. My 150 can turn a 21 4 blade so I'm sure your 300 can do alot better. And the props scb are using are called turbo props
Sun Mar 17, 2013 1:02 pm
i thought full throttle had the turbo props...SCB has an article on mercury's website for doing testing of the new promax prop..and from all what i have seen they mostly run bravo Ixs's...If I was you I would get with a reputable prop shop and get their opinion on a starting point to swap to the bravo prop..you have only 2 degrees of pitch to work up and down...your hull will lift more with a bravo I so its hard to tell how it will react..im no expert so I would know what to tell you.
http://www.mercuryracing.com/blog/pro-max-prop/
Sun Mar 17, 2013 4:32 pm
Is it a tuned 250 sho?
Sun Mar 17, 2013 4:36 pm
Sun Mar 17, 2013 5:02 pm
I suggest you contact Mark Croxton at http://marksprops.com/
He is unbelievable on props and has excellent service. I sent my Tempest plus to him and he sent it back with a gain in top end and bottom end. Just give him a call and he will be glad to talk to you.
Sun Mar 17, 2013 5:11 pm
And nobody has thought to zoom in on the pix of the Toyota boat yet?
Green 17x54 GatorTail Extreme gettin' chased by a Green 35 GTR
Sun Mar 17, 2013 7:21 pm
It hit 70mph @6100rpm.....Looking at the numbers, he thinks if i sacrafice some bottom end, i can get ~73mph with a higher pitch prop...
Sat Mar 30, 2013 8:49 am
Talk to baggy
Sat Mar 30, 2013 9:13 am
Sat Mar 30, 2013 9:16 am
What were your rpm's trimmed out?
Sat Mar 30, 2013 3:24 pm
Sat Mar 30, 2013 3:41 pm
U should be able to go up a size or 2
Sat Mar 30, 2013 3:55 pm
Personally I would buy whatever baggy suggest
Sat Mar 30, 2013 4:27 pm
Sat Mar 30, 2013 5:39 pm
Sat Mar 30, 2013 7:46 pm
Put a fury on that bitch
Sun Mar 31, 2013 7:15 am
FD,,,I would love to try a "fast 3 blade"....I think i can get the boat into the low 70's pretty easy..
Tgunn,,,,this whole prop game for me started when a friend of mine that runs a legend 250xs combo told me to try a Bravo1!! He told me he tried 5 different props and it was the fastest by 4mph....
So i called a Mercury racing dealer,,these guys are pretty much mercury to the bone! They recomended the OT4. He said on pretty much all boats they tried it on, it blew away the bravo1....
I have a friend with a 24yellowfin that just bought a Bravo1 Fs like you are talking about. He was running a rev4 so when he gets back from Destin, we will see how it does compared to the Rev4 on his boat, and i may try it also...
I can tell you,,this OT4 has a huge amount of lift!!! It has like 28deg of rake built in!!!!
Whats cool about the Turbo props is they perform great, and are much much thicker then the merc props, and are about 100 dollars cheaper...
I may see if baggy can work some majic on this one...It was chilly friday morn, but i was still able to get 6200rpms...
For the record,,,i had a 250 etec,,,and this engine will destroy it!!! The power is unreal....Also,,it had a noticable differnce after i got some hrs on it....Not sure if they are "detuned for breakin" but def felt a diff...
Sun Mar 31, 2013 8:02 am
Turbo/Stiletto (PPI) makes great props and they are waaaaay underrated.
Tough to beat this place for prices:
http://www.boatownersworld.com/Props/turbo/turbo.htm
My old Redfisher 18 really liked the Turbo I and that's where I would get them from.
PS, not saying the SHO didn't have lots of power. That's why we were puzzled by the rpm issue on the bigger boats.
Sun Mar 31, 2013 8:08 am
Sun Mar 31, 2013 8:15 am
I personally don't like the bravo on a bay boat. 1 good mud flat, oyster reef or sand bar and that prop is done. It's a good prop, but it's really really thin. The fury outdid a bravo, by far, a tempest, and a laser on my bass boat. They r really thick too. If u do go with a bravo, at least baggy is near u. Not many people can fix em.
Sun Mar 31, 2013 8:37 am
Sun Mar 31, 2013 8:45 am
Yeah I get that. I don't have a bullet Allison gambler or stroker and I'm not doing 80+. I have a z8 with a 225pro xs turning a 25 fury. I can drive with 1 finger at 75. I could use a Lil more hole shot tho, if both live wells r full of water and a full tank of gas it hesitates getting on step. I could probably take the plugs on the wheel completely out, but they r just reduced right now. The tank is like 48-52 gallons so I just fill it up to half way and it doesn't seem to be an issue
Sun Mar 31, 2013 8:51 am
Sun Mar 31, 2013 8:59 am
Whatever u come across, black jacks r really nice. And 60-70
In a bay boat is a dream. U should b happy
Sun Mar 31, 2013 9:10 am
Yeah im good,,,i just knew the ole SWS2 Prop wasnt the best combo...
Sun Mar 31, 2013 9:30 am
Users browsing this forum: No registered users and 119 guests
