It is currently Mon Dec 22, 2025 5:44 am
Reply to topic  [ 20 posts ]
 welding question
Post welding question
Whats your thoughts on butt welding two sheets of 5'x12' together to make a bottom for a skiff? Bottom thickness is .190 aka 3/16 5052. I have checked with my local steel/alum supplier and he said twelve foot was the longest sheet he could get. I would have to have the twenty foot sheets shipped in which I would prefer however I would like to build me a skiff sometime in the next couple months. The five by twelve sheets of .190 cost $400 per piece.
18x48 GDSD boat
Tue May 07, 2013 6:38 pm
Post Re: welding question
try to find a diffrent aluminum supplier cause we get 20 foot sheets down here in louisiana all the time cause it cost more to get a cut sheet!!!
Tue May 07, 2013 7:04 pm
Aluminum & Stainless or Pierce Aluminum
Both have places in New Orleans and Broussard
Tue May 07, 2013 7:27 pm
he is in indiana, not la
Black ops IITX marshstalker
1840 WC www.wccustomboats.com
fuel injected 25 GTR
Tue May 07, 2013 7:28 pm
It's not ideal, being it's going to take more time and attention to keep everything fair, but any aluminum boat over twenty feet is going to have a seam weld, so it's no big deal if done right. We use to seem those 5x12 sheets together all the time on 12' decked over air boat hulls and never had that center seem fail. I've welded on many 100'+ aluminum crew boats and there made of many sheets welded together
Tue May 07, 2013 7:57 pm
Mandel metals in Chicago carries a wide range of material and will have 20 footers
Pete Willett
WC Custom Boats - Tyler, TX
http://www.wccustomboats.com
Tue May 07, 2013 8:11 pm
Thanks a bunch guys. I really appreciate your input.
18x48 GDSD boat
Tue May 07, 2013 8:15 pm
X2 I don't see a problem with it at all especially on 3/16. Get good penetration and you will be fine
Tue May 07, 2013 9:06 pm
Out of curiosity, would you chamfer the ends of the sheet before welding to help with penetration? Or just weld flat end to flat end?
Every day I'm paddlin'
Tue May 07, 2013 9:17 pm
For what he's doing I would bevel the edges and leave a small gap between the sheets
Tue May 07, 2013 9:22 pm
X2. Just be careful when buffing the weld not to dip into the sheet.
Tue May 07, 2013 9:27 pm
Wed May 08, 2013 5:07 am
It's gonna b hard to keep the weld seam from getting distorted, or dog legging.
18'x54"CC Hanko/ 36PD
Wed May 08, 2013 2:14 pm
Wed May 08, 2013 2:20 pm
On .188" material I wouldn't bother with beveling the edges. I would leave a .188 gap and use a .188 backer plate. The backer plate will help with some of the distortion.
Mag 10
Thu May 09, 2013 11:07 am
Im having to pay 2.50 per pound here locally. I called Mandel in Chicago and it was 1.87 per pound. They had one twenty foot 3/16 in stock however no idea of when they will have more. I am going to call Tals buddy at Pearce and see what I can come up with.
Thanks for the replys.
18x48 GDSD boat
Thu May 09, 2013 11:11 am
Thu May 09, 2013 12:16 pm
Thu May 09, 2013 12:42 pm
K Im not sure. Tal said he could hook me up.
18x48 GDSD boat
Thu May 09, 2013 3:12 pm
"Would the backer plate be used structurally? Or just to avoid weld splatter?"
It is somewhat structural. It is used to focus the depostion between the components that you are trying to join. The weld nugget will tie the 2 sheets and the backer stip together instead of letting the energy just blow through the gap and thus bettering the posibility of a complete joint penetraion. Because you are adding a strip of material you are creating a "backbone" along that joint that can help with distortion along the length of the weld.
Mag10
Fri May 10, 2013 11:52 am
