It is currently Sun Jun 09, 2024 12:24 pm
Reply to topic  [ 18 posts ]
 Back fire after gutted
Post Back fire after gutted
Motor runs great. took bog out. Now backfires from WOT.
What the hell do I do ??
Wed Jun 05, 2013 10:54 am
Post Re: Back fire after gutted
got a leak some where
- Mark Twain
Wed Jun 05, 2013 10:58 am
Adjust ur carb that's what I did
When you gutted it, did you leave the stock outlet pipe?
Wed Jun 05, 2013 11:02 am
Wed Jun 05, 2013 11:03 am
Yes I left the stock outlet pipe. Also turned the idle jets out to 2.5 turns. That removed the bog
Wed Jun 05, 2013 11:30 am
Go some more
Wed Jun 05, 2013 11:31 am
past 2.5 turns on idle jet ? how much ?
Wed Jun 05, 2013 12:01 pm
How Far Did You Stick The Outlet Pipe Into The Can?
1754 XSeries Kawi Powered PRODRIVE ...
Wed Jun 05, 2013 4:34 pm
I kept the original outlet pipe and just drilled additional holes inside the can. Breathes much better and throttle response is great but now it back fires.
Also opened up the air idle to 3.5 turns.
Wed Jun 05, 2013 4:46 pm
Mine did the same. Head job fixed it. A head job is always the answer. Lol
Wed Jun 05, 2013 4:56 pm
Wed Jun 05, 2013 5:40 pm
Thu Jun 06, 2013 4:40 am
Steady air stream coming behind this fitting. But I think its welded on the inside ? Could it be the cooling fan air or is this fitting leaking.
How do you test it ?
Thu Jun 06, 2013 9:24 am
you would know if its hot exhaust air .... most likely the cooling fan venting near there, prolly to help cool it.
Black ops IITX marshstalker
1840 WC www.wccustomboats.com
fuel injected 25 GTR
Thu Jun 06, 2013 12:24 pm
Yep, it's just the fan air. FYI, I ported that carb intake some also. Fatten it up a lil more.
1846 GTB & 35 GTR
Team Gator-Tail
(409) 720-8949
Thu Jun 06, 2013 10:52 pm
Is it backfiring only when you rev and let off with no load. If so, that is pretty typical for these open exhausts. If it is still doing it when you rev and let off under load (prop in water) then worry about it.
Mag10
Fri Jun 07, 2013 11:03 am
Running great. Opened up the idle air mixture 3.5 turns. No bog. No backfire under load. Only backfires on land at WOT to zero.
Problem is going away on its own. Motor is still breaking in. I think it's starting to run better.
Thank you all !
Fri Jun 07, 2013 3:51 pm
Users browsing this forum: No registered users and 191 guests
