It is currently Sun Jun 09, 2024 9:17 am
Reply to topic  [ 34 posts ]
 Home brewed muffler pics?
Post Home brewed muffler pics?
Gotta put together a muffler now and can"t make up my mind what I want it to look like. I think I'm gonna make it with two outlets but just can't make up my mind yet.
Normally I only say this to girls but, "Show me your exhaust". :mrgreen:
Modded 36 PD draggin' around an 1848 PD boat backwards!
Thu Jun 06, 2013 10:09 am
Post Re: Home brewed muffler pics?
Copy the EVT
Thu Jun 06, 2013 10:16 am
Did evt make the whole exhaust or did they buy a muffler and weld the flanges and outlets to make it fit a vanguard?
Thu Jun 06, 2013 10:18 am
1846 GTB & 35 GTR
Team Gator-Tail
(409) 720-8949
Thu Jun 06, 2013 10:20 am
So is it a muffler you can buy off the shelf?
Thu Jun 06, 2013 10:21 am
No
Thu Jun 06, 2013 10:23 am
They sure look like a car mufflerImageUploadedByTapatalk1370536740.026297.jpg
Thu Jun 06, 2013 10:39 am
Thu Jun 06, 2013 10:43 am
Mandrel bent primaries, separate chambers and outlets for each cylinder, drilled baffle plate with a deflector after it. All 304 SS
Mag10
Thu Jun 06, 2013 11:17 am
Least u dont have to have to worry ab it rusting!
Thu Jun 06, 2013 11:18 am
Thu Jun 06, 2013 11:31 am
Thu Jun 06, 2013 11:41 am
Hard for something to rust that a magnet won't stick too
Thu Jun 06, 2013 11:44 am
Build it out of a duplex stainless like 2205 and it won't rust even in salt water
Thu Jun 06, 2013 12:02 pm
Or if u just love spending money can alway go with 6moly can leave that on bottom of ocean for couple years and pull up with no rust
Thu Jun 06, 2013 12:04 pm
Thu Jun 06, 2013 12:10 pm
Hmmmmm........
The wheels are turning.
Thu Jun 06, 2013 1:17 pm
The flanges coming off the motor are stainless but mufflers are not!!
Gotta keeps kegs in business some how!!
Thu Jun 06, 2013 1:23 pm
Thu Jun 06, 2013 1:26 pm
Rule of thumb from what I have always heard the higher the grade stainless the less mag. Draw it has so therefore mag won't stick. But never had an earth magnet. Normal use not including harsh chemicals won't make 304 rust or rot compared to the 400 series which is more corrosive resistant thin mild steel. But I was to vague in my comment.
Thu Jun 06, 2013 1:45 pm
Make sure to dispose of contents before cranking her up:
Thu Jun 06, 2013 1:52 pm
1846 GTB & 35 GTR
Team Gator-Tail
(409) 720-8949
Thu Jun 06, 2013 3:30 pm
A lot of people don't know that stainless steel is actually rust resistant rather than totally rust proof, and can be damaged very easily by exposure to direct heat at high temperatures like in an exhaust system. Its actually an iron alloy that contains a minimum of 11.5 wt% chromium (which gives it that nice shine), but the carbon is what really gives it strength and the resistance to rust /or staining. The 304 when exposed to high temperatures is more susceptible to oxidation and color change.
Thu Jun 06, 2013 10:17 pm
Sounds like you did your homework Bayouboy. I believe you.
Fri Jun 07, 2013 6:44 am
The more carbon the more likely to rust. The molybdenum (MO) also referred to as moly the more corrosion resistance hence why I said a duplex 2205 which isn't much more expensive than 316 will hold up much much longer in a basic (saltwater ph ~ 8) environment and is twice as strong and 316 stainless.
Fri Jun 07, 2013 6:45 am
Here is mine. 304SS sch 10
Fri Jun 07, 2013 7:16 am
Nice job!
Fri Jun 07, 2013 9:32 am
Good work!
Fri Jun 07, 2013 10:20 am
Bet that thing warms up quick.
Fri Jun 07, 2013 10:23 am
1850 & 36pd
Fri Jun 07, 2013 10:29 am
Fri Jun 07, 2013 10:40 am
Fri Jun 07, 2013 12:22 pm
Users browsing this forum: Google [Bot] and 185 guests
