It is currently Tue Jul 08, 2025 11:21 am
Reply to topic  [ 17 posts ]
 PD 36 stock muffler
Post PD 36 stock muffler
Does anyone have the part number for a stock Briggs muffler? I want to keep a spare on hand.
Thanks much, Wayne
Thu Aug 08, 2013 3:43 pm
Post Re: PD 36 stock muffler
Got one a while back from MB cheap. They site will show if they have any stockers on hand
PRODRIVE 1860 CC
"Let the good times roll"
Sun Aug 11, 2013 1:00 pm
Just remember if it comes off a horizontal motor
The outlet will be pointing down if installed on a vertical motor like a pd
Sent from my iPhone using Tapatalk 2
1854 GTB Extreme 35GTR
Sun Aug 11, 2013 4:39 pm
yep didnt cause any issues though
PRODRIVE 1860 CC
Sun Aug 11, 2013 7:29 pm
I was told it will bolt up but the outlet will be pointing straight down. Might be able to weld a 90 on it to turn it toward back. Great price though.
Mon Aug 12, 2013 5:16 am
They are a little better quality that the stock PDs.
1754 XSeries Kawi Powered PRODRIVE ...
Mon Aug 12, 2013 7:57 am
You have one?
Mon Aug 12, 2013 10:22 am
Call the Boat Dr. in Harahan
He sells stocks that are take-offs when he does engine mods.
Mon Aug 12, 2013 10:34 am
Mon Aug 12, 2013 10:36 am
Reason I ask is I made my own for my 07'.
But I have recently bought the hydro reverse kit and I don't have the room to install the Hydro ram, exhaust it too tight of fit.
So I'm either gonna make another one, or buy a stock one and gut it. The sotck one will already give me the clearance for the ram, so alittle less fab work.
You have any picks of it? How did you manage the outlet pipe sticking straight down?
Mon Aug 12, 2013 11:55 am
I will get you some pics. But I got a 1-1/2" 90 from all purpose pipes toned it down some. you can't beat the price and you can gut one in a few hours.
Mon Aug 12, 2013 2:49 pm
The only bad thing about the MB muffler is the outlet pipe is welded to the other side of the can. So to get the guts out you have to cut a hole in the side of the muffler and then patch it. The 90 helps keep the sound from bouncing off the water. I rolled a piece of 16 ga 304 SS and welded it to the bottom. It keeps the outlet pipe from falling out from all the vibrations.
Tue Aug 13, 2013 4:49 am
Thats not bad at all. My outlets were 1.5" 45's. I was gonna gut it anyway and weld the outlet pipe in it. I mainly needed the header offset so the ram would fit. I have everything to make another, just no time right now. So you basically put a weld pad around the pipe. Welded the plate to exhaust and ran outlet pipe through both.
Tue Aug 13, 2013 5:18 am
Yea, I took a hole saw and cut a hole in the plate and welded I out all the way around. I have had 2 vibrate and break the can. This should solve that problem.
Tue Aug 13, 2013 6:22 am
Tue Aug 13, 2013 9:56 am
Tue Aug 13, 2013 2:47 pm
Wed Aug 14, 2013 1:19 pm
Users browsing this forum: No registered users and 123 guests
