It is currently Fri Apr 03, 2026 8:19 am
[ 7 posts ] |
captmike
 Need advice
I have a 54 x 16 semi v all weld boat and want to put mud motor on it. Travel up to 10 miles to hunt in river and open water, but have lots of shallow water to cross. Any suggestions? Thanks, Capt. Mike
| Wed Oct 28, 2009 7:46 am |
oleman
 Re: Need advice
Before I purchased an engine, spoke to different manufactures and vendors, none of them recommend a V bottom boat. You need to got and test them all. If you want reverse, either PD or GT.
_________________ 16 x 48 Alweld - 36 PD FPR PT&T
| Wed Oct 28, 2009 11:08 am |
Spike Buck
Joined: Tue Aug 25, 2009 1:00 pm Posts: 23 Location: Morgan City La.
 Re: Need advice
I know a guy with a 35hp Gaytortail on a boat pretty close to yours & it does just fine.
_________________ blood stained bateau with a lawnmower engine on the back
| Wed Oct 28, 2009 11:30 am |
richardb
Joined: Wed Feb 11, 2009 9:47 am Posts: 351 Location: Fresno, Ca
 Re: Need advice
I have a 16x52 Lowe w/ a 35 MB it is not a speed demon and the hull is not the strongest but gets the job done for right know. Here is the link to my review. viewtopic.php?f=5&t=4596
_________________ 1652 w/ MB Mini 35
| Wed Oct 28, 2009 12:14 pm |
captmike
 Re: Need advice
Thanks for the info. It is appreciated. Capt. Mike
| Wed Oct 28, 2009 8:46 pm |
JD
 Re: Need advice
Mike if its got a slick bottom and goes back to a shallow v or flat it will do fine. It can't have any hook or V crimps on the bottom. You will want a longer SD like the gd. I would want to bolt one on a do a test drive on your boat.
JD
| Thu Oct 29, 2009 4:53 am |
captmike
 Re: Need advice
Thanks for the info. Capt. Mike
| Sun Nov 01, 2009 5:29 am |
[ 7 posts ] |
