It is currently Fri Dec 26, 2025 12:48 am
Reply to topic  [ 21 posts ]
 Greasing prodrive tower issues
Post Greasing prodrive tower issues
Pulled the lower Allen plug on my tower section to grease it and a piece of dark green plastic was in the way enough where I can't get the grease gun on the grease zerk. What is it and I assume its not supposed to be there?
Wed Oct 30, 2013 9:37 am
Post Re: Greasing prodrive tower issues
That's the lower Teflon sleeve. 3 things can be going on. 1) it wasn't cut at the factory, 2) it rotated, 3) it could have cracked/broke.
Wed Oct 30, 2013 10:37 am
So what should I do? Can I get away with grinding it down a little to grease it then teardown next February after the season? I do know I operated the reverse once with the tension knob tight.
I'm pretty sure it was this way when I got it at 72 hrs. But the previous owner did break the knuckle off and had it repaired at a local pd dealer, maybe they didn't cut it?
Wed Oct 30, 2013 11:01 am
I would drop the foot and check it out. It takes no time at all.
Wed Oct 30, 2013 11:15 am
This is the bushing they are talking about Alex
Wed Oct 30, 2013 11:21 am
The bushing goes between the aluminum sleeve and tower.
Wed Oct 30, 2013 11:28 am
Can I get away with another 5-10 hrs run timer till the split? It should be fine the bushing is still there?
Wed Oct 30, 2013 12:03 pm
Does it have much play in it? If not, I would think so as long as it feels smooth turning it. But I'm going to be responsible. :lol:
Wed Oct 30, 2013 12:25 pm
did you turn the motor to see if the hole lines up?
mine didnt line up perfectly with the zerk.. I heated a old screw driver and melted the teflon
I gave up mud motors
Wed Oct 30, 2013 12:28 pm
^ this is a good idea. When I changed mine I had this problem but used a hole saw with the drill bit removed. it was sketchy but worked.
Wed Oct 30, 2013 12:43 pm
The hot screwdriver worked great. Got the bushing out of my way and greased up. There's not much play in my knuckle, based on what I've seen on here not enough to worry about. I'm going to run it for the season and tear down after. I can only hunt weekends and none of my spots are that far.
Wed Oct 30, 2013 2:31 pm
I replaced my bushings and there is no grease fitting on mine. ??? I just have the one at the top and bottom but nothing in the middle. ???
If I turn out the plug I see the green bushing too but there's nothing behind it if I did mash a hot screw driver through it. I don't get it.
I'm thinking of sleeving mine because I do have a little play in it.
Modded 36 PD draggin' around an 1848 PD boat backwards!
Thu Oct 31, 2013 5:40 pm
What year is your motor? 04-07 there is no grease fitting, all oil bath.
Thu Oct 31, 2013 6:10 pm
I guess I do have an older tower. ? Who knows what year that is. My clutch had an '07 sticker on the top of it.
Sat Nov 02, 2013 6:57 pm
Year model will be stamped on the side of the transom mounting bracket. Mine says PD10 for 2010.
Tue Nov 05, 2013 6:22 pm
I have never been able to get into mine. got the top and bottom and tried to get into it and rounded it out. It is a PD 2008 model. should I be worried about this?
Tue Dec 17, 2013 8:10 pm
Wed Dec 18, 2013 5:54 am
Wed Dec 18, 2013 5:58 am
image.jpg if it's worn when you pull it down like mine was put a stainless sleeve on it
Wed Dec 18, 2013 8:07 am
:shock: I want one!!!
Wed Dec 18, 2013 8:50 am
Wed Dec 18, 2013 10:58 am
