It is currently Sun Apr 12, 2026 6:48 am
Reply to topic  [ 3 posts ]
 Valve cover gaskets
Post Valve cover gaskets
Just wondering if new gaskets are required when valves are adjusted on a mm or do yall just reinstall them as is. Should i use new gaskets or sum sort of forma gasket?
Wed Nov 06, 2013 11:15 am
Post Re: Valve cover gaskets
Only if they leak, wipe them off real good and reuse them.
Wed Nov 06, 2013 11:19 am
Just be careful when you pull the covers off and make sure they aren't torn. Mine stayed on the heads when I pulled the covers off. Gentley wipe them down and wipe the surface of the cover down that touches the gasket. Toqure cover bolts to 70 in lbs. As long as the gasket isn't damaged it should seal back up. No need to use any gasket sealer. If they leak get new gaskets.
Wed Nov 06, 2013 2:47 pm
