jtwilliams
Joined: Wed Oct 09, 2013 10:20 am Posts: 167 Location: Central LA
 fastest hull???
I know this is going to start an opinion war. But on average what is the fastest hull? also with chines, or without chines?
| Mon Nov 11, 2013 4:03 pm |
btmannin
Joined: Tue Jan 15, 2013 5:25 pm Posts: 1723 Location: Oxford/Jackson ms
 Re: fastest hull???
simply put.. square tends to be a little faster, slides in turns, Round chine drafts more, a little slower and doesnt slide when turning at high speed.... and then there's tapered chines: Single, double, triple, single being most similar to a round,, and triple being similar to square.
_________________ 1436 tin can shoved by a 16 GDLT 16.5x48 running like hell from a built 40 merc
| Mon Nov 11, 2013 4:08 pm |
dadazzsaleen
Joined: Tue Nov 09, 2010 11:24 pm Posts: 743 Location: Mandeville, LA
 Re: fastest hull???
^^ triple taper is closer to round. There's 3 bends in the chine.
A single taper is more like a 45 degree vs a 90 degree of a square.
_________________ [Stage 2.5]
| Mon Nov 11, 2013 4:16 pm |
eljefe
Joined: Thu Jan 13, 2011 7:32 am Posts: 5210 Location: Beaumont Texas
 Re: fastest hull???
Instagator. ....
sent from the former Republic of Texas.
_________________ You can't see the sunrise if your eyes are closed. dying aint much of a livin....
Black ops IITX marshstalker
1840 WC www.wccustomboats.com fuel injected 25 GTR
| Mon Nov 11, 2013 4:22 pm |
nasty
 Re: fastest hull???
17x48 square chine. If we're talking stock motors.
| Mon Nov 11, 2013 4:23 pm |
btmannin
 Re: fastest hull???
| Mon Nov 11, 2013 4:43 pm |
cupped up
Joined: Tue Jun 05, 2012 7:25 pm Posts: 4205 Location: St. Amant, LA
 Re: fastest hull???
STV's are pretty fast. They're tunnel hulls though. Allison XR2001's roll too, they are V bottom pad hulls, kinda a stepped chine design.
| Mon Nov 11, 2013 5:49 pm |
jtwilliams
 Re: fastest hull???
im talking stock motor 35hp
| Tue Nov 12, 2013 12:39 pm |
banded-mallard
 Re: fastest hull???
17-18' 48"-54" bottom, lite as possible. Depending on what and where you hunt, go 1/8" bottom, .100 sides, hat section for ribs. Want to say luceur had a hull made that was all .100 for a GTR25. Thats about as lite as you can go. But if you run any kind od swamp or trees or stumps, you should go 3/16 bottom. Weight has as much to do with the hull design.
| Tue Nov 12, 2013 1:06 pm |
270Handiman
Joined: Thu Dec 29, 2011 10:46 pm Posts: 2342 Location: Mandeville, LA
 Re: fastest hull???
This is easy..........whatever boat AKAwhatever is in. Just ask him, he'll tell you. Whatever you get, you're gonna have chines of some sort, you just have to decide how you want them shaped.
| Tue Nov 12, 2013 2:51 pm |
Jamie B.
 Re: fastest hull???
| Tue Nov 12, 2013 3:13 pm |
dfou
Joined: Sun Dec 12, 2010 12:38 am Posts: 3986 Location: Pville, La
 Re: fastest hull???
| Tue Nov 12, 2013 4:08 pm |
AKA Freshwaterkilla
 Re: fastest hull???
| Tue Nov 12, 2013 7:58 pm |
banded-mallard
 Re: fastest hull???
| Wed Nov 13, 2013 5:31 am |
Swamp Wader
 Re: fastest hull???
17 48 square
| Wed Nov 13, 2013 5:49 am |
Will
 Re: fastest hull???
The rake effects top speed also, changes how much surface area you have on the water. You want just enough flat bottom it to get on top like a skim board and not cutting through the water creating drag. The width is a variable in this as well.
_________________ Before the internet, the majority of the village idiots stayed in their villages.
| Wed Nov 13, 2013 6:26 am |
Woodiebuster
 Re: fastest hull???
But, a longer more gradual rake will plane out and run much better
| Wed Nov 13, 2013 12:19 pm |
Will
 Re: fastest hull???
You should say and, not but... you're adding to what I was saying and have a point.
| Wed Nov 13, 2013 12:25 pm |
banded-mallard
 Re: fastest hull???
| Wed Nov 13, 2013 12:50 pm |
dfou
 Re: fastest hull???
I think he means like this And the correct answer to the question is, whatever hull my motor is on
Sent from my iPhone using
| Wed Nov 13, 2013 1:20 pm |
Will
 Re: fastest hull???
| Wed Nov 13, 2013 1:30 pm |
banded-mallard
 Re: fastest hull???
| Wed Nov 13, 2013 1:33 pm |
dfou
 Re: fastest hull???
| Wed Nov 13, 2013 1:34 pm |
dfou
 Re: fastest hull???
Although this one is a big boat with a short rake and ran the same speeds as y'all's
| Wed Nov 13, 2013 1:36 pm |
eljefe
 Re: fastest hull???
Instagator..... they got mojo in them.....
| Wed Nov 13, 2013 5:46 pm |
Boomer
 Re: fastest hull???
_________________ 1748 Boomer Custom in progress
| Thu Nov 14, 2013 9:44 am |
banded-mallard
 Re: fastest hull???
| Thu Nov 14, 2013 10:01 am |
jtwilliams
 Re: fastest hull???
you building them yourselve? and that rake being so long how does it do in rougher water?
| Thu Nov 14, 2013 10:17 am |
banded-mallard
 Re: fastest hull???
| Thu Nov 14, 2013 10:32 am |
Jamie B.
 Re: fastest hull???
| Thu Nov 14, 2013 10:33 am |
banded-mallard
 Re: fastest hull???
| Thu Nov 14, 2013 10:35 am |
dfou
 Re: fastest hull???
| Thu Nov 14, 2013 11:30 am |
banded-mallard
 Re: fastest hull???
| Thu Nov 14, 2013 12:01 pm |
Will
 Re: fastest hull???
Second mark 37-39, that's that throw a fucker off a cooler shit right there
| Thu Nov 14, 2013 12:09 pm |
Bigrich
Joined: Wed Dec 19, 2012 7:52 pm Posts: 7064 Location: Mallard country
 Re: fastest hull???
That hull was like a 100 gauge too.
| Thu Nov 14, 2013 12:16 pm |
dfou
 Re: fastest hull???
| Thu Nov 14, 2013 12:18 pm |
banded-mallard
 Re: fastest hull???
| Thu Nov 14, 2013 12:20 pm |
instagator911
Joined: Sat Dec 05, 2009 12:36 pm Posts: 1127 Location: Behind the hood next 2 da bright light! SETX
 Re: fastest hull???
_________________ Jay Dore
| Thu Nov 14, 2013 12:24 pm |
Bigrich
 Re: fastest hull???
| Thu Nov 14, 2013 12:28 pm |
instagator911
 Re: fastest hull???
Its no prob. there are a list of things that will make a hull faster and set right. most importantly is drying the hull for less drag. Not all hulls are the same i.e. 1646 vs 1646.
| Thu Nov 14, 2013 12:32 pm |
