It is currently Mon Feb 23, 2026 8:20 am
Reply to topic  [ 5 posts ]
 35 gtr Clutch Smoke in reverse
Post 35 gtr Clutch Smoke in reverse
Stuck to Chit last week and I guess I did not hold the reverse lever hard enough. Clutch smoked for a few seconds. Turned off motor for 10 minutes. Put it in forward works fine
What do I need to inspect to make sure clutch is ok ?
Thank you.
Fri Nov 29, 2013 4:03 pm
Post Re: 35 gtr Clutch Smoke in reverse
Take off clutch cover, look for debri, its card to inspect clutch without taking apart.
Sent from my DROID RAZR using Tapatalk
Fri Nov 29, 2013 4:25 pm
Probably wasn't the clutch smoking...reverse has nothing at all to do with the clutch. Don't you have the 3rd gen caliper? They're junk, pads slip too much. Probably the pads smoking. You're probably fine just inspect the pads for heat damage and the rotor...then roll with it.
Fri Nov 29, 2013 7:11 pm
Didn't even see reverse in my tapatalk, cupped up is right sounds light pads, i had to go to a different caliper setup on mine.
Fri Nov 29, 2013 7:20 pm
Your clutch is not smoked at worst it will cost you 130 bucks for new rotor and break pads .
17/54 gator tail extreme with a stage 2 gator tail strapped on the back
viewtopic.php?f=5&t=43412
Sat Nov 30, 2013 9:00 am
