It is currently Tue Dec 23, 2025 11:54 am
Reply to topic  [ 13 posts ]
 GT Tiller Handle Nut
Post GT Tiller Handle Nut
A guy I hunt with is running an early GTR. He's having issues with the tiller handle nut working loose every trip. It's got to the point now that he keeps a wrench in the boat to tighten it up after every run to keep it from falling off while driving. Regardless of how much you tighten it, it starts to work loose when you lift the handle.
Is there an easy fix for this or was this an issue that was redesigned somewhere down line or something?
Mon Dec 02, 2013 7:04 pm
Post Re: GT Tiller Handle Nut
Try red lock tite.
Mon Dec 02, 2013 7:10 pm
Try a new lock nut.
Mon Dec 02, 2013 7:23 pm
Mon Dec 02, 2013 7:26 pm
Mine is a 2012 and it gets loose so no new design as of then
gtr35 gt 1854 / w gatorglide
12 ft 11hp longtail
14 ft 10 hp longtail
Merc 225hp TR20
Put a new metal lock nut on it.
Mon Dec 02, 2013 7:27 pm
Mon Dec 02, 2013 7:39 pm
What is that? I thought y'all were saying use a backup nut.
Mon Dec 02, 2013 7:42 pm
So we're basically just trying to find something that will work here i guess. Maybe use 2 stainless washers back to back to create a pivot point then the locknut?
Mon Dec 02, 2013 7:45 pm
If its giving him that much trouble I would get a longer bolt If needed and put jam nuts on it! That would fix the problem for sure.
Sent from my beeper.
Mon Dec 02, 2013 7:48 pm
Just weld the nut to the bolt. Prob solved.
Sent from my iPhone using Smoke Signals
1646 Gatortail dragging a stage 1 GTR
Mon Dec 02, 2013 7:56 pm
Once again, a new lock nut.
Mon Dec 02, 2013 8:03 pm
Mon Dec 02, 2013 8:20 pm
