It is currently Mon Dec 22, 2025 6:32 am
Reply to topic  [ 27 posts ]
 GTR issue
Post GTR issue
I few weeks ago I I squeezed my reverse lever to back out of a launch and as soon as it went into reverse my motor caught a extremely bad vibration so bad that I killed the motor quick. when I took the back cover off one of the caliper pads fell out. the rotor had a bad wobble to it and it basically destroyed the whole caliper so I pulled the rotor off and the key way pin looked messed up so I figured that let the rotor lose and cause it to wobble an cause vibration. I just got around to changing the key way today and it still has the same wobble. no idea why and I have a few calls into gator tail the last few days with no return phone call. any ideas ?
Sent from my iPhone using
16x44 Hanko Skiff
35GTR
Mon Dec 16, 2013 6:21 pm
Post Re: GTR issue
Any run out in the shaft with the rotor removed?
You sure you didn't call MB....Gatortail guys are always there to talk to anyone who may call, no matter what else is going on.
Mon Dec 16, 2013 7:45 pm
Post Re: GTR issue
Are you sure the planetary sections are together. If the main bolt backed out, could have caused it to come apart, causing gears to not be lined up
Sent from my DROID RAZR using Tapatalk
Mon Dec 16, 2013 8:34 pm
Post GTR issue
they are together all the way. and I've 3 phone calls saying Hoyt won't answer his phone in the last couple of days not complaining about costumer service here just askin what y'all think could be wrong with the motor
16x44 Hanko Skiff
35GTR
Mon Dec 16, 2013 9:02 pm
Post Re: GTR issue
have you removed the shaft extension to verify the key is securely in place?
Mon Dec 16, 2013 9:14 pm
Post Re: GTR issue
When you say key way, what are u describing
Mon Dec 16, 2013 9:16 pm
Post Re: GTR issue
i think hes talking about the keyed washer under the main bolt head
Mon Dec 16, 2013 9:17 pm
Post Re: GTR issue
Look at the planetary assembly and rotor with the engine running in neutral. You said it only does it when you engage the reverse, but the planetary and rotor spin constantly. If its not doing it with the engine running in neutral that eliminates those two links. Did one of the Allen head bolts loosen on the ring gear housing to cog gear connection? Is the ring gear mounted flush and evenly on the gear? Look at it running in neutral then lock it in reverse on the trailer and just watch what's happening. How's your belt tension?
Mon Dec 16, 2013 9:19 pm
Post Re: GTR issue
Mon Dec 16, 2013 9:20 pm
Post Re: GTR issue
it does it in neutral and it's just the last part of the planetary with the caliper on it that's wobbling. my motor never had a shaft extension in it
16x44 Hanko Skiff
35GTR
Mon Dec 16, 2013 9:23 pm
Post Re: GTR issue
never had a shaft extension through the planetary at least
16x44 Hanko Skiff
35GTR
Post Re: GTR issue
Mon Dec 16, 2013 9:28 pm
Post Re: GTR issue
If you take the caliper off and grab the rotor can you wiggle play into the planetary?
Mon Dec 16, 2013 9:29 pm
Post Re: GTR issue
Sounds like planetary is not together correctly. Pull the main bolt. take a peak inside believe its six Allen heads, then reinstall planetary (rotor side) make sure it aligned with key on shaft and the gears are meshed together properly. If this is not done, will cause wobble!
Mon Dec 16, 2013 9:31 pm
Post Re: GTR issue
everything is lined up correctly and tight the rotar is not loose in the planetary but when runnin it is way off
16x44 Hanko Skiff
35GTR
Tue Dec 17, 2013 12:11 pm
Post Re: GTR issue
If everything is lined up and tight and there's no slack in anything it seems like its gotta be the planetary gear set itself got fucked up some kinda way.
Tue Dec 17, 2013 12:30 pm
Post Re: GTR issue
yea that kinda sucks right in the middle of huntin season
16x44 Hanko Skiff
35GTR
Tue Dec 17, 2013 12:37 pm
Post Re: GTR issue
Just dont use reverse.....gigga has been doin it like that since 1970.
Tue Dec 17, 2013 12:48 pm
Post Re: GTR issue
that's what I was plannin on doing but it doesn't do it only in reverse it does it at all times while running
16x44 Hanko Skiff
35GTR
Tue Dec 17, 2013 1:01 pm
Post Re: GTR issue
Make sure the rotor is stirring flush on the planetary and not up on the lip
Tue Dec 17, 2013 1:29 pm
Post Re: GTR issue
it is flush
16x44 Hanko Skiff
35GTR
Tue Dec 17, 2013 1:32 pm
Post Re: GTR issue
never heard of or seen this happen before
16x44 Hanko Skiff
35GTR
Tue Dec 17, 2013 1:40 pm
MMT Moderator
Post Re: GTR issue
My output shaft got severely screwed up on my motor one year. I allowed the bolt to back out of the back of the shaft which caused the entire assembly to get loose and warped the crank shaft of the motor. That's what I got for neglecting simple maintenance like making sure the bolts are tight. :evil:
That fiasco also started my quest for internal mods :mrgreen:
GTB 1860 w/ 2019 GTR40XD-HO
Tue Dec 17, 2013 2:04 pm
Post Re: GTR issue
the first thing I checked was the shaft. if you take the back of the planetary off it is not whopped at all. out it back on and that's the bad wobble
16x44 Hanko Skiff
35GTR
Tue Dec 17, 2013 2:13 pm
Post Re: GTR issue
video of it running
16x44 Hanko Skiff
35GTR
Tue Dec 17, 2013 2:27 pm
Post Re: GTR issue
It looks like the PTO shaft is bent or the planetary gear is messed up. You could check it by draining the gear oil and pulling the inside part of the gear out that the rotor is attached to. I think you can put the long bolt back in without the inside part of the gear installed. Run it without the inside part of the gear and see if that outer planetary housing spins true. If it does than it is the planetary that is messed up. If it doesn't than the PTO shaft is probably bent. If it is just the planetary you could just run it without the inside gear to get you by while you get a new planetary sent to you. Probably be a good idea to replace the grease seal in the outer planetary housing if you have to get a new internal gear set.
Tue Dec 24, 2013 1:08 am
Post Re: GTR issue
I'm pretty sure the planetary is messed up. any idea how this happens ? or the price of a new planetary
16x44 Hanko Skiff
35GTR
Tue Dec 24, 2013 1:16 am
